I Phone and Nokia on Call manager version 6
Can anyone help in registering Nokia( N and E) and I Phone registering with Call manager version 6. Only a patch from Cisco will help? or need call manager to upgrade to later versions?
Firasath
Hi Firasath.
If you want to use nokia call connect for Cisco CUCM, you can download phone software and cop file to install into CUCM from the following link.
http://europe.nokia.com/support/product-support/nokia-call-connect-for-cisco/compatibility-and-download
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Thanks for the info provided. Instead of using cop file for Nokia, can i use third party sip Devices in call manager.
Yes. You can configure a basic third party SIP Phone on CUCM 6.x.
Refer to the following link Third-Party SIP Phone Configuration Checklist
Carlo
440
