Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
I want to play a msg before call routed to DN
I would like to play a “this call may be recorded” message before a call is sent to a DN. If possible I'd like all calls at a remote location to experience this whether they reach the auto-attendant on the main number or call a user direct via a DID.
We have a Unity Connections 1.2 - that will be upgraded to the latest version soon, and a CM 5.1 that will be upgraded to 7 soon.
Can an interview handler or Call Handler play the message and then pass the call on without caller input?
1 ACCEPTED SOLUTION
Re: I want to play a msg before call routed to DN
A call handler will suffice. In the greetings portion of the call handler config, just set to send caller to a particular extension after the greeting is played and disable caller input on the call handler.
Hope that helped.
Hope that helped.
Kenneth is correct - a Unity CH will provide this functionality; something to be careful of, is the number of license ports on your CUC if you want all calls to be handled by it in the first instance.
109
