IAD2431
boonchin.ng
Just wondering, does this platform - Cisco IAD2431 able to support E1 R2?
Thanks and best regards.
gogasca
Level 10
Level 10
- The E1 R2 signalling is not supported on the IAD2431
- Additionally, although the VWIC-E1 cards can support R2 signalling, this is not a solution supported on the IAD2431, so at this point we can say that officially E1 R2 is not supported on the IAD2431, regardless if the E1 port used is located on board or if it is located on a VWIC-E1 card.
gogasca
Level 10
Level 10
Hi GASCA,
Thanks for the reply.
