IAD2432 problems with old Merlin SX200 PBX
We have a customer with a very old Merlin SX200 PBX that is connecting to the T1 port of our IAD2432.  After a lot of experimentation and constulting other teams in my company,  I was able to get this setup so they could send and receive calls, but at least once a day, something happens and they are no longer able to make calls anymore.  I am out of ideas.  Can somebody please help, if possible?
Below is the essential parts of the configuration of the IAD:
isdn switch-type primary-dms100
isdn logging
voice rtp send-recv
voice service pots
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
   outbound-proxy dns:clwr.knologyvoip.net
voice class codec 1
codec preference 1 g711ulaw
Sep  3 12:23:56.770: ISDN Se1/0:23 Q931: SETUP pd = 8  callref = 0x0055
        Bearer Capability i = 0x9090A2
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Calling Party Number i = 0x2180, '7272093762'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '5401900'
Sep  3 12:23:56.770: ISDN Se1/0:23 Q921: Net TX -> RR sapi=0 tei=0 nr=84
Sep  3 12:23:56.774: ISDN Se1/0:23 **ERROR**: L3_Go: SETUP Rejected
Sep  3 12:23:56.774: ISDN Se1/0:23 Q921: Net TX -> INFO sapi=0 tei=0, ns=63 nr=84
Sep  3 12:23:56.774: ISDN Se1/0:23 Q931: RELEASE_COMP pd = 8  callref = 0x8055
        Cause i = 0x808618 - Channel unacceptable
voice rtp send-recv
voice service pots
voice service voip
sip
voice class codec 1
controller T1 1/0
isdn logging
clock source internal
pri-group timeslots 1-24
controller T1 1/1
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
controller T1 1/0
controller T1 1/1
no ip address
encapsulation hdlc
no cdp enable
If there are any other pieces of the config you may need to view, please let me know.  Below is the error that occurs from the debugs I have running (q921 and q931):
                Standard = CCITT
1 REPLY
Hall of Fame Super Gold
Errors comes from PBX, so most likely fault is on that side.
However,check "show controllers T1, and try comparing with a working call.
169
