05-23-2007 06:39 AM - edited 03-14-2019 09:40 PM
I need to up the RAM in my 3 7815 ibm call manager servers and cannot find a IBM part number. I tried to order from my Cisco reseller and they asked for the IBM part number as well. Does anyone know how to order ram for these servers?
05-23-2007 07:01 AM
This memory modules are supported:
Description Marketing part number Replacement part number
512 MB PC2-4200 ECC DDR2 SDRAM DIMM 30R5148 30R5151
2 GB kit (2x 1 GB) PC2-4200 ECC DDR2 SDRAM DIMM 30R5149 30R5152
4 GB kit (2x 2 GB) PC2-4200 ECC DDR2 SDRAM DIMM 30R5150 30R5153
06-12-2007 07:20 AM
I ordered the 2 gb kit model # 30R5149 and it did not even fit. My servers are 3 years old, could they have changed the RAM. I opened a ticket with Cisco and they are not sure. There is no IBM markings on the server so I can not even go direct with IBM. Any help would be great.
06-12-2007 08:44 AM
OK, I just pulled these numbers out of the server.
M71IX MB
02160-1
48.53S01.011N2
Also I found this on the ram that was in the box
1gb ddr 333 cl2.5 ecc pc2700u-25330-b0
I need 4 gb kits
Thanks to anyone who has a part #
