ICCS defined QoS Policy
Can someone please share a defined QoS policy map for ICCS Cluster over Wan CUCM 7.1.3 or the best way to match traffic for all ICCS
class-map match-all VOICE-RTP
  description VOIP Bearer Traffic
match access-group name VOICE
class-map match-all VOICE-CONTROL
class-map match-all ICCS
policy-map VOIP-QOS
  description Set DSCP for VOIP Control, ICCS and Bearer Traffic
class VOICE-RTP
  priority percent 33
  set ip dscp ef
class VOICE-CONTROL
  bandwidth 16
  set ip dscp cs3
class ICCS
  bandwidth 1500
class class-default
  fair-queue
Re: ICCS defined QoS Policy
ICCS appears to be a third party contact center solution that runs SIP?
  match access-group name VOICE   <----Make sure this ACL matches UDP 16384-32767, and also whatever ports ICCS uses for RTP.
match ip protocol skinny
match ip protocol sip
No need to have a separate queue for ICCS, since it looks to be mostly SIP and you'll catch that in the control queue.
If you know what DSCP values ICCS uses, you can classify on DSCP instead of using NBAR or ACLs.
This may not be what you want but this document (under wan considerations) may lead you to the info you need to do a granular policy. One other consideration depending on your topology would be to classify based on the layer 3 addresses of the subscribers to the publishers.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/models.html#wpxref88775
440
