Community Member
icon library for IPT
Hi, where do you guys find the Visio icon library for Cisco Telephony? I got one from here: http://www.cisco.com/iam/unified/ipt1/Microsoft_Visio_Network_Topology_Diagrams.htm. It's kind of old, CUPS icon is not in it.
Jonathan
1 ACCEPTED SOLUTION
Re: icon library for IPT
You can check here:
http://www.cisco.com/web/about/ac50/ac47/2.html
The visio PMS 3015.zip has a CUPS icon.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
You can check here:
HTH.
Bill
Community Member
Thanks, William!
661
