ICS 7750 Drive failuer
We have a ICS 7750 with SPE 310 running Call Manager 3.1(3a). We had a failed drive. The ICS is no longer covered by SmartNet. We have ordered the systems for upgrade Unified Communications Express but that is still a month away.
Can I replace just the IDE drive on the existing SPE 310 or do we need to (somehow) get our hands on another SPE 310 w/ the drive - will replacing just the drive on the existing SPE work?
1 REPLY
Anonymous
N/A
Re: ICS 7750 Drive failuer
To install and use Cisco ICS 7750, you must have an ICS 7750 chassis equipped with SPE310 cards. The SPE310 offers a keyboard/mouse port, a video port, and two universal serial bus (USB) ports that support standard USB devices such as CD-ROM drives. Refer the following documents:
http://www.cisco.com/en/US/docs/routers/access/ics7750/software/notes/icsspe23.html
http://www.cisco.com/en/US/docs/routers/access/ics7750/software/26/troubleshooting/guide/winreim2.html
96
