ICT between cucm 8.x and cucm 4.x
madan.kumar
Any idea whether ICT between 8.x and 4.x will work? is there any chalenges? cud u pls assist
Thanks in advance
Madan
Jaime Valencia
It will work, no special config or considerations.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks java thats extreamly helpfull full points to u
It will work yes, but be aware that if you plan to include the ICT in a route group you can't use QSIG tunnelling in the H.323 ICT. QSIG tunnelling is useful if you would like features such as call back and Message Waiting Indicators.
Tore:)
