ICT Failover for long distance GW
We have Two CCM (6.1)Clusters. Cluster A and Cluster B. Calls b/w the Clusters are working through ICT non-gatekeepers. However we would like to setup failover that if long distance PRI failed in ClusterA, we would like to route those calls to Cluster B long distance Gateway by adding ICT to Long Distance Route List with less priority. We have access code to dial long distance and discard digits predot within cluster and access code for inter-cluster calls.
Is this possible?
Any assistance/guidance would be highly appreciated....THANKS
Green
Re: ICT Failover for long distance GW
CLuster 1 - ICT - Cluster 2
Yes it should work.
Route pattern
9.1[2-9]XX[2-9]XXXXXX - RL LD
LD RL contains
RG1 LocalPRIGW
RG2 ICT
You send either the complete number to clusterB or remove 9 depending how ur config in cluster B is for LD calls.
Remember that ur ICT in Cluster B CSS, should have access to a Route Pattern for LD
one more thing i want to add to the great info from GONZALO
which is if u have the codec between clusters as g729 in this case u need to take into consideration the need of an Xcoder
thank you
158
