Silver
ICT one Way
I have an ICT between two clusters A and B - it works one way A-B but not the other B to A- I get fast busy. The DNA on site B shows the call hitting the ICT and sending the correct extension number but still getting fast busy. I`ve tried it with a site code being stripped off on site A and just with extensionsn numbers but still not working
Green
Re: ICT one Way
Silver
Re: ICT one Way
Thanks, I did not have the corrrect region settings- should stop using my phone as a test phone!
134
