Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ICT QSIG Call Preservation
Hi Techs
Does ICT QSIG preserves the call during the following scenario.
CUCM fails in a cluster A. In the lab CUCM service parameter ***Allow Peer to Preserve H.323 Calls *** is set true. But the call is not getting preserverd when the calling IP Phones CUCM goes down.
IP Phone ---> Cluster A CUCM ICT w QSIG ----> GK ----> Cluster B CUCM ICT w QISG ---> IP Phone.
Peter
Re: ICT QSIG Call Preservation
Any help pls ???????
Green
Not supported at this time.
H.323 version 5 incorporated Annex R called "Robustness methods for H.323 entities" which make it feasible.
You may contact your AM since there is already a PERS for this.
Green
My bad it is supported.
Can you upload the traces as well as CCM version?
Green
If u remove the GK it works?
179
