Community Member
ICT
are inter cluster trunks able to look at all the servers in the cluster. I have my ICT set up and it point to both pub and sub but when the pub is offline calls are not able to get accross. Should this work?
Silver
Re: ICT
The most important thing with an intercluster trunk is to ensure that it is configured with a one-to-many relationship with respect to each cluster.
So, on cluster one, create an intercluster trunk to each of the servers in cluster two, i.e. the publisher and all subscribers that phones register too. Then on cluster two, create an intercluster trunk to each of the servers in cluster one, i.e. the publisher and all subscribers.
Depending on the numbers of servers in each cluster, you might have to create multiple ICTs since each ICT can only connect to three servers.
This should take care of things for you.
This document helps out as well....
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094729.shtml
If this helps, please rate.
Community Member
Re: ICT
ok this is what I have set up.
cluster 1 = ICT1A = clutser 2 Pub / Cluster 2 Sub
Clutser 2 = ICT2A = Cluster 1 Pun / Cluster 1 Sub.
it seems that when the pub is down on cluster 2 no calls can get through to a phone on cluster 2
Silver
Re: ICT
If I'm not mistaken, the trunk will have a device pool setting as well (sorry, not at my terminal right now). If so, make sure that the device pool for each clsuter has all the subscribers available to it.
Confirm that, or perhaps you can copy the trunk config page for each cluster to the forum for us to review.
Community Member
Re: ICT
I have checked my DP and the CMG contains both CM. Please see screen print of ICT setup
thanks
140
