10-09-2013 02:25 AM - edited 03-16-2019 07:47 PM
I have a doubt, my customer has ask me if is possible identify incoming calls by name instead of by number, looking for in internet I found this, my question is if anybody has doing this before, and if is possible, because i dont know how to identify the name, how to get the database of names.
isdn supp-service name calling
Facility IE -> what is this??
At the voice service level:
voice service voip
h323
h225 timeout ntf <50-5000> (we used 500 successfully)
h225 h225 display-ie ccm-compatible
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_i2.html#wp1115928
thanks!
Solved! Go to Solution.
10-09-2013 02:54 AM
Hi Ivan
I think this is impossible , and i have doubt for that i think you can ask your Teleco.
Thank you
please rate all useful information
10-11-2013 12:10 AM
Hi Ivan,
you can achieve that with a external database with contacts and with using a TCL app configured at particular DPs.
Then it is not needed to have the name of caller within the signalization getting from ISDN.
I can really recomend the 2Ring PHONE SERVICES which provides such solution.
If it is interesting for you, use the link: http://www.2ring.com/NewJuice
HTH,
Martin
10-09-2013 02:43 AM
When you receive a call on Voice Gateway, the gateway uses dial-peers to match and decide on what needs to be done with the call. dial-peers can match based on Calling or Called Party number. It does not support name match. Also, please note that providing a calling party name is not a mandatory from ISDN standards. Not all calls recieved on the Gateway have a calling party name. Therefore even trying to do a match using name could cause multiple calls to fail.
Also, the commands you have mentioned,that is for outbound calls, to be able to send name to your Telco.
10-09-2013 02:53 AM
Hi mkchandak
Ok thanks understood.
So the only way to receive all calls by name is contacting with service provider and ask for enable it?
In the case to get it, what will be the commands to send calls from GW to CUCM?
thanks!
10-09-2013 03:02 AM
Hello
I think you can use the below URL which will help you for your issue , you have to use 3rd party or script to allow your CUCM do lookups for the incoming call.
http://www.ciscoxmlservices.com/it/tcl--ivr-scripts
Thank you
10-11-2013 12:55 AM
islam.kamal wrote:
Hello
Please note the above link is not valid anymore. The correct site is mentioned in my profile.
10-09-2013 02:54 AM
Hi Ivan
Thank you
10-09-2013 03:19 AM
ok islam thanks for your reply.
regards.
10-09-2013 08:21 AM
I have caller name on pri with local carrier. Pri had to have the feature enabled at the central office.
10-09-2013 08:28 AM
Hi Robert
Ok!!! so it is possible, which are the commands? because i thought was these one but seems not.
Facility IE isdn supp-service name calling
Facility IE
If not could you please kindly say me the commands?
Thanks!!
10-09-2013 08:56 AM
all I could find that seemed relevant was isdn switch-type primary-ni and
voice service voip
voice class h323 1
h225 timeout tcp establish 2
h225 timeout ntf 1000
h225 display-ie compatible
I had to do isdn debugs to see if carrier was really sending the name, they were not and when they started sending everything worked.
I am not able to do caller name at other sites because the type of pri we use to get features will not support name delivery
10-11-2013 12:10 AM
Hi Ivan,
HTH,
Martin
10-11-2013 12:40 AM
ok Martin thank you very much for the link.
I will study that solution because it seems much better than try operator send the name, which i think here in spain is not possible to get it.
Regards!
10-11-2013 12:46 AM
Calling name from telco is available only in the US and Canada.
For a general solution, you can use my "number to name" script, it can be acquired on the website mentioned in my profile.
10-11-2013 01:09 AM
That is what i was thinking, in spain is not possible, thanks!
I wanted to use a solution based in CLI because customer did not have a CUCX, but now has acquired one, so I can try to resolve the problem with a script.
Ok paolo i will get your script and test it, thanks!
10-11-2013 01:14 AM
My scripts are not for CUCX. They work directly on the voice gateway and are configured with CLI.
