Identify Internal Calls and External Calls In CCME
Is there any way that we can identfiy internal and external calls in CCME.
If possible can we make it ring differently?
Is it possible to treat the internal call and external call differently?
for example.
I have an extention A, A is busy, Normally when A is busy All the call are forwarded to the reception. I dont need if the person calling is from an internal extension to reach recpetion. Only external callers should reach.
Faizal
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Identify Internal Calls and External Calls In CCME
Try "no forward call internal" under ephone-dn.
Thanks for your suggestions. I just tried this. It works...Another issue comes after this like no one is able to transfer the call from thier extension to my extension.
Faizal
You are welcome, please remember to rate useful posts clicking on the stars below.
I appreciate if you could suggest any workaround on the issue i am facing when I enabled this..?
Faizal
Please open new threads for new problems.
Thank you for the nice rating and good luck!
215
