Community Member
Identifying inbound vs. outbound
Is there a way to tell if calls on my MGCP gateway are inbound or outbound on my T1 PRI ?
I was running the following commands, and none gave me an indication. I am sure there is a command for this...
sh voice call sum
sh voice call stat
sh call active voice brie
Re: Identifying inbound vs. outbound
I normally just do a quick look at what channels are in use and then verify if telco is sending in top down and we are sending out bottom up.
Matt
Community Member
Never thought about it that way....good idea.
you can also use CCM detailed traces. debugs voice ccapi inout and debug isdn q931
Community Member
I was hoping to avoid debugs...but you are correct.
Thanks!
119
