iec description from router
Need help as i cant make outbound calls from h323 gateway. Telephone extension is configured on CUCM.
Router is 2901
IOS is "flash0:c2900-universalk9-mz.SPA.151-4.M.bin"
RTR# sh voice iec description 1.1.186.5.7.5
    IEC Version: 1
    Entity: 1 (Gateway)
    Category: 186 (Signaling socket failure)
    Subsystem: 5 (H323)
    Error: 7 (Socket error)
    Diagnostic Code: 5
VIP Super Bronze
Re: iec description from router
Can you send the ff:
sh run
debug voip ccapi inout
debug ip tcp trans
please attach via notepad. dont post outut directly here
Lets have a look at whats going on..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Dear I have uploaded the requested information in notepad
VIP Super Bronze
But you have not attached it here.... (never mind I have see it)
let me know what the calling and called number is
VIP Super Bronze
Please call confirm what your setup is..
ipphone--->cucm----->h323gateway..........>PSTSN
is this correct?
Is your h323 gateway showing its ip address in cucm? or is the state showing as status: unknow, ip address: unknow
it shoule be status: unknow and ipadress: x.x.x.x (where x.x.x.x=gw ip add)
From your trace, the call is not coming into gateway from cucm...I cant see any inbound call setup...
and we see this:
008049: *May 26 14:18:05.668: TCP0: Connection to 10.50.2.4:52377, advertising MSS 536
008050: *May 26 14:18:06.044: TCP0: state was SYNRCVD -> ESTAB [1720 -> 10.50.2.4(52377)]
008051: *May 26 14:18:06.044: TCB2B176FC0 accepting 30E11CC4 from 10.50.2.4.52377
008053: *May 26 14:18:06.044: TCB30E11CC4 setting property TCP keepalive timeout (17) 2B4C0104
008056: *May 26 14:18:06.244: TCP0: ACK timeout timer expired
So it suggests that CUCM and gateway are not talking properly
ya this setup is correct.
I can ping the CUCM from gateway as shown below:
MCTRTR#ping 10.50.2.3 sou lo10
Sending 5, 100-byte ICMP Echos to 10.50.2.3, timeout is 2 seconds:
Packet sent with a source address of 10.1.210.193
Success rate is 100 percent (5/5), round-trip min/avg/max = 376/381/384 ms
MCTRTR#ping 10.50.2.4 sou lo10
Sending 5, 100-byte ICMP Echos to 10.50.2.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 376/383/392 ms
status on cucm is status unknown and IP Address is 10.1.210.193
Even i also cant dial inside (sorry, forgot to mention)
Let me tell you...i have added one cisco phone in cucme mode and call is coming in both direction. but phones registered on cucm are unable to call in both direction
VIP Super Bronze
On the gateway can you try this..
telnet 10.50.2.4 1720 (to see if this port is open)
what do you get?
Is there a firewall between them? cucm and gateway?
Hello Omerpal,
Did you reload the router?
Can you reload the router if not done already.
Hope this helps!
Karthik
I cant telnet at port 1720 it must be restricted. There is no firewall between gateway and CUCM. I have configured GRE Tunnel in order to reach CUCM. This setup is also done at one site and its working fine.
I have also restarted the router, but nothing happened.
DEBUG CCH323 SESSION AND ERROR
000069: *May 26 17:34:52.263: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
000070: *May 26 17:34:52.263: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
000071: *May 26 17:34:56.531: //-1/xxxxxxxxxxxx/H323/cch323_ct_main: SOCK 0 Event 0x1
000072: *May 26 17:34:56.535: //-1/xxxxxxxxxxxx/H323/cch323_get_new_ccb: ccb (0x2C7DE4DC) is in use
000073: *May 26 17:34:57.263: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
000074: *May 26 17:34:57.263: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
000075: *May 26 17:35:02.263: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
000076: *May 26 17:35:02.263: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
000077: *May 26 17:35:07.263: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_RAS_GLOBAL_MSG_TIMER] expired
000078: *May 26 17:35:07.263: //-1/xxxxxxxxxxxx/H323/cch323_iev_queue_service: Dispatch 0x1A internal event to RAS Global SM
000079: *May 26 17:35:11.535: //-1/xxxxxxxxxxxx/H323/cch323_timer_dispatch: Timer[CCH323_H225_CONNECTION_TIMER] expired
000080: *May 26 17:35:11.535: //-1/xxxxxxxxxxxx/H323/h323_gw_clean_send_blocked_watch: fd 3
000081: *May 26 17:35:11.535: //-1/xxxxxxxxxxxx/H323/h323_set_cc_cause_for_spi_err:
Categorized cause:38, category:186
000082: *May 26 17:35:11.535: %VOICE_IEC-3-GW: H323: Internal Error (Socket error): IEC=1.1.186.5.7.5 on callID -1
000083: *May 26 17:35:11.535: //-1/xxxxxxxxxxxx/H323/h323_set_release_source_for_peer: ownCallId[-1], src[6]
000084: *May 26 17:35:11.535: //-1/xxxxxxxxxxxx/H323/cch323_cleanup_xport: IP_entry is NULL, returning
VIP Super Bronze
If you cant open port 1720, then that suggests that tcp port is blocked between cucm and the gateway. This  port is what they communicate on..as you can see from the trace the gateway was sending packets to the publisher on that port. You need to look at your gre-tunnel and see why this port is blocked..
I have one more site where voice is working with GRE Tunnel. Is it country dependant factor?
VIP Super Bronze
I dont think it is country dependent..It is just that in this scenario the port needed to work is not opened..You need to find out why and make configuration changes if need be
1496
