iLBC codec packetization issue
I have video call between two phone as below
9971 -- CME --- CUBE ----CUCM --- 9971   (delay offer)
call from cme end to CUCM end works (video and audio) h264 and iLBC
call from CUCM end to cme end connect(video works) but no audio (can see on phone both ends Rcvr discarded) due to cucm end doing 30ms and CME end doing 20ms
Debugs on CUBE shows CME send offer with 30ms but CUBE send offer to CUCM without any ptime ?
CUBE has codec transparent on both ends.
Try asymmetric payload full
Try asymmetric payload full under voice service voip > sip.
Do this on both CUBE and CME.
use codec ilbc mode 30 at
use codec ilbc mode 30 at your CME End
I had the same issue. I
I had the same issue. I resolved it two ways.
The less preferred way:
Go to the inbound and outbound dial-peers on the CUBE. On the dial-peer enter the command
codec ilbc mode #
where # is the lower of the two ptime values. In this instance 20 (from CME side) is lower so the command for this scenario is
codec ilbc mode 20
The more preferred way:
We can tell CUBE to passthru the SDP. I recommend doing it on the dial-peer instead of doing it globally:
CUBE#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
CUBE(config)#dial-peer voice <tag>
CUBE(config-dial-peer)#voice-class sip pass-thru content sdp
CUBE(config-dial-peer)#end
CUBE#wr
Building configuration...
[OK]
CUBE#
539
