ILO configuration on MCS 7845H2 server
I am planning to upgrade Callmanager on MCS 7845H2 remotely. This is in a production environment. I am not able to find the ILO IP address configured on this server.
Is there a way to identify the ILO IP remotely or by logging into the console?
If not, please let me know if there is any document which can guide to re-configure the ILO for this server. Is there any configuration required on MCS server like assignemt of IP address etc?
Karthik
  • IP Telephony
CUCM GUI or CLI do not show
CUCM GUI or CLI do not show anything regarding the ILO config of the server, you would need to refer to HP guides in order to find out how to change your current config.
java
if this helps, please rate
www.cisco.com/go/pdi
Issue is resolved.I tried to
Issue is resolved.
I tried to check via BIOS boot screen on the server. The option to configure ILO was not showing up. Raised a case with HP. Vendor changed the system board and configured new ILO on the server.
The only way to configure iLO
The only way to configure iLO (If you don't know any of the details) is via the BIOS boot screen on the server.
If the iLO is unconfigured, then it's probably set to DHCP, and the default username & password will be on a label on the front of the server.
GTG
Please rate all helpful posts.
That is easy,  -physically
That is easy,
-physically check waht switch port the iLO ethernet if. is connected to.
-check the cam-table on the switch to find whcih MAC the iLO NIC it has
-check the arp table on your L3 device for that MAC address.
 get your password and user ID and log in.
If you find no IP address, than it is most likely not configured,.
============================= Please remember to rate useful posts, by clicking on the stars below. =============================
VIP Gold
You can access the server
You can access the server using ILO port using http://ILO<Serial#OfBox>
For example serial id for server is XXYYO1234567, then use http://ILOXXYYO1234567
Suresh
478
