ILS Configuration issue CUCM 9.1.1
I have configured ILS on two CUCM 9.1.1 clusters (Hub and Spoke). They authenticate using password (not with certificate). The spoke seems to have registered to the hub. However, the clusters do not seem to see each other.
  Advanced Features -> ILS Configuration ->ILS Clusters and Directory URI Imported Catalogs (bottom section ) is emty on Spoke and on Hub this section contains only Hub cluster.
On the Hub i can see following info:
Found 1 hub cluster(s), 0 spoke cluster(s), and 0 directory URI imported catalog(s).
On the Spoke I can see follwoing info:
Found 0 hub cluster(s), 0 spoke cluster(s), and 0 directory URI imported catalog(s).
The clusters have uniques cluster IDs in Enterprise Parameters.
The tomcat-trust certificates have been exchanged (although this step was not necessary, since I am using password authentication.
If anyone has any ideas, please help.
Everyone's tags (5)
Hi 1-Is this configuration
1-Is this configuration for URI dialing?.
2- Cancel registeration , specify HUB  and specify password then save a page will appear registeration server press ok without adding any ip address . Then go the other Spoke and type same password , after that a page will appear type the IP address of your HUB.
3- Go to services on each cusm and restart intercluster domain lookup service.CUCM - servicabilty - Services
Please rate all useful information
HIDid you configure SIP trunk
HI
Did you configure SIP trunk between two CUCMs "HUB&SPoke"?.Device-Trunk
Did you configure a SIP route pattern?. call routeing-sip route pattern.
Did you configure intercluster Directory URI  configuration?.call routing- intercluster Directory URI -intercluster Directory URI.
please rate all useful information.
HI1-Can you answer the above
HI
1-Can you answer the above questions?.
2- Status on HUB and spoke on the bottom of page of ils configuration "ILS clusters and directory
URI  Imported ?. I need to see the status , if the integration is ok you have to see up to date .
please rate all useful informration
Hi,1. Yes the SIP trunk is
1. Yes the SIP trunk is configured with the SIP profile including the FQDN parameter.
2. Yes. The SIP route pattern is configured.
    a) On HUB it is "br.com" pointing to SIP trunk to Spoke
    b) On spoke it is "hq.com" pointing to SIP trunk to HUB
3. The option Intercluster Directory URI Configuration (with Exchange Directory URI Catalogs with Remote Clusters) iis checked on both HUb and spoke:
    a) On HUB it is "hq.com"
    b) On spoke it is "br.com"
I wll provide you the scrrenshots rearding ypur next next question.
Thanks, Regards
HiCan you try the below:
Can you try the below:-
1)hq.route
2)br.route
Go to enterprise paramater on each CUCM
and change cluster ID
1)HQ.com
2)BR.com
and do again the ILS  , then restart the services .
Please rate all useful infromation
Hi,I have attached the
I have attached the screentshots.
1. Do you want me to change SIP troute patterns to hq.route and br.route?
2.I will try it with upper case.
HiYes , try to change SIP
Yes , try to change SIP route pattern to hq.route and br.route?. And change enterprise parameteres on each cucm to HQ.com and BR.com any name as you wish.To change enterprise parameters go to cucm - system - enterprise parameters - cluster id " chnage it". After that do again ILS.
Note: This is after ILS ok on SIP Trunk check that you enable under outgoing calls -calling and connected party Info format " select Deliver URI and DN in connected party , if available ".
please rate all useful information .
Hi1- Based on your attached
1- Based on your attached file.
2- Please change the password on ILS to do again the ILS , then restart the services on each CUCM and wait for some time . Did you get an error that registering is take a long time ???.
Hi,I have done the changes
I have done the changes and verified the SIP trunks.
Everything it OK - by the book.
Changed the password I do not get the error message about the registration taking too long. Spoke is registerd after 15 seconds.
Informational MessageStatus: Ready
Informational MessageFound 0 hub cluster(s), 0 spoke cluster(s), and 0 directory URI imported catalog(s).
Informational MessageRegistered Successfully.
HiSo your issue solved ??,
So your issue solved ??, can you share with me same output which you sent before regarding status on ,docx .
Hi,The issue is not solved.I
I get these status messages, but still hub sees 0 spokes and spoke sees no hub in the status below.
Although as you can see the registration statsus of the spoke to hub seems OK.
I have it working in my lab
I have it working in my lab configuring each server as a HUB, I got 10.0 and 10.5 and it works just fine. Just make sure the SIP route pattern exactly matches the RHS of the URIs, and that you configure the same as the advertised route string.
java
if this helps, please rate
www.cisco.com/go/pdi
hi,There is one more thing
hi,
There is one more thing that might be of importance.
Since it is a lab environment, the Spoke cliuster has not been installed from scratch but it is a copy of the HUB CUCM VM (hostanme and IP address have been changed and certificates regenrated)
Do you think it can be causing such problems? (some sort of identity mismatch)
I am currently reinstalling the clusters.
Hi Piotr,
Hi Piotr,
I see that no answer take into account the point that you have one copied VM. I got the same issue with a different version (11.0) and we have in common this point of copied VM. The CLI command "utils ils showpeerinfo" give the same "Peer Id" for the two machines. I think it can cause a problem in synchronization.
Sorry to be 2 years late, but it can help somebody else...
I had the same issue, and
I had the same issue, and fixed it using the following procedures
- Remove the cluster domain and fqdn on service parameters in both sites;
- Cancel the registration in the spoke cluster
- Saved the spoke cluster again, with the hub Publisher IP;
- Restarted ILS service
- Wait the synchronize time.
HILook i just tested on same
HI
Look i just tested on same version , it was working without any issues.Can you try to make it again :just change the "password" and select HUB after save kindly check that HUB configuration overwrite standalone , and same for Spoke. Check also the SIP trunk between the both clusters "on the sip trunk destination ".Restart service intercluster look up helped me to solve same issue for one of my customers.
Hi,Thanks for tyour promt
Thanks for tyour promt answer:
1. Yes my intention is to use URI dialing.
2. The registration seems to be successful. There is no "Cancel" button anymore. I can change Spoke back to Stanalone cluster. Then change it back to Spoke and enter the IP of the hub as the registration server. I have already doen it before.
3. I have just restarted ILS service on Hub and Spoke. Did not change anything.
Hello
Hello
try this solution:
ON YOUR HQ site:
for each user on End user, specify his uri dialing: like hquser1@cisco.com
 Associate each ip phone with his user (owner id), do same on DN
Create Sip profile by coping the standard, named URI-SIP-PROFILE, on it
check "Use Qualified Domain Name in SIP Request"
Create CSS named URI-CSS and add partition uri directory on it
on CSS of DN user choose URI-CSS
Create SIP Trunk named URI-TRUNK, choose URI-SIP-PROFILE
in inbound call CSS choose URI-CSS
Create SIP Route Pattern to you br like: br.route, choose URI-TRUNK
on Intercluster Directory URI Configuration, check Exchange Direct. uri and on
Route string: hq.route
Go to ILS configuration, choose Hub Cluster, set password (be carfull must same on Br)
click on save, set nothing on ip registration, click ok
ON YOUR BR site:
for each user on End user, specify his uri dialing: like bruser1@cisco.com
on CSS on each DN choose URI-CSS
Create SIP Route Pattern to you hq like: hq.route, choose URI-TRUNK
Route string: br.route
Go to ILS configuration, choose Spoke Cluster, set password (be carefull must same on hq)
click on save, set ip address of QH publisher, click ok
after 2 minutes click on Refresh, You ILS successfully registered!!!
Try dialing URI,
it will work fine:)
1642
