09-22-2017 06:01 AM - edited 03-17-2019 11:13 AM
We have a 2 server IM&P cluster version 9.1. High availability is enabled. I need to move the Publisher from an old UCS to new UCS machine. I have performed a fresh install on the new hardware and then restore from a backup of the legacy publisher. When I go to the restore wizard I can get the listing of the backup, but it wants to do a restore of both servers, I do not get the option to select just a restore for the publisher. I have tried to see If I can do a backup of just publisher, but I don't get the option. Backup will only backup entire cluster.
We have been running on the subscriber for a few days so If I do a restore of cluster I assume I will lose any changes since backup?
Anyone advise on the best way to restore Publisher?
09-22-2017 07:08 AM
Whu don't you shutdown the VM and move it to the other server?
Or use vMotion?
09-22-2017 07:11 AM
09-22-2017 08:04 PM
Hi There,
If transferring the files from one UCS manually or via vMotion is not an option, you should still be able to re-build the publisher node manually and restore the backup.
The DRS restore documentation has the procedure laid out for restoring a publisher only.
Step 1 | Select Navigation > IM and Presence Disaster Recovery System from the menu in the upper right corner of Cisco Unified CM IM and Presence Administration. | ||
Step 2 | Select Go. | ||
Step 3 | Enter the same Administrator username and password that you use for the Cisco Unified IM and Presence Operating System Administration . | ||
Step 4 | Select Restore > Restore Wizard. | ||
Step 5 | On the first screen of the Restore Wizard, select the backup device from which to restore. | ||
Step 6 | On the second screen of the Restore Wizard, select the backup file that you want to restore. The backup filename indicates the date and time that the system created the backup file. | ||
Step 7 | On the third screen of the Restore Wizard, select the features that you want to restore. Only the features that were backed up to the file that you select display. | ||
Step 8 | On the final screen of the Restore Wizard, select Restore to start restoring the data Select to restore your data to the first node only (the publisher).
Step 9 | Restart all nodes in the cluster. |
Are you saying that on step 8 of the above procedure, there is no option to resotre the data to only the first node?
Yes, if you restore the publisher data from a backup you will lose the IM&P changes since the backup.
09-22-2017 11:24 PM
09-24-2017 08:14 AM - edited 09-24-2017 01:51 PM
You should be able to restore a single node
09-24-2017 08:30 AM
09-24-2017 11:43 AM
I cannot understand why you cannot just shutdown the IM Publisher, export it as a single OVF file to a Windows PC and then upload it to the new UCS.
I have just done this for a customer whose UCS C210 M2 servers were approaching End of Support.
I moved the CUCM, IMP, Unity and UCCX servers using this method and (once I figured out that I needed to set the MAC addresses on the new CUCM, Unity Connection and UCCX servers to those of the old servers) everything went without a hitch.
No vSphere/Vmotion or other fancy stuff needed - just a Windows PC with a decent amount of free storage space and a bit of time.
09-24-2017 01:46 PM
James,
I actually saw a post of yours a while back and I ust say I have never seen this method before. Can you kind,y enumerate what you did here and why didnt you go the option of backup, install new OVA and deploy vms on new hardware, then restore and ofcourse migrate licenses...
Always good to learn new ways of doing things, but I also like to know the why...
09-24-2017 01:59 PM
There is not much to the process. I am not in front on the system at the moment but, from memory, the process is:
09-24-2017 02:06 PM
The process I described in my previous post seemed the obvious way to do things tbh. My reasoning was that I had a perfectly good VM which could be easily migrated to a new host and the process seemed more efficient than backup/rebuild/restore.
For most of my deployments I actually export the Publisher servers in the manner described so that I have a simple way to rebuild in the event of a disaster. This is a matter of deploying the OVF and restoring the latest DRS backup. It is quicker than a complete rebuild especially if there are lots of additional files (locales, firmware etc.).
09-24-2017 01:50 PM
According to the documentation here..
You should be able to restore only the publisher node. What you have to bear in mind is that at some there will be dbreplication between the two nodes. Now the database on the pub is older than that of the sub..so what happens next..I am not sure..With CUCM the answer is clear..I am not sure for IM and P
