IM/Presence 9.1 - Calling name incorrect when calling Jabber
We had a user that left the company.  A new hire took over the extension.  We removed the primary line of the old user in CUCM, and used it for the new hire.  When some calls the extension, the recieving end still sees the old user's name.
I tried removing both users from my contact list in Jabber, and still the old name appears.  When calling a deskphone, the proper name appears.
I confirmed that the extension doesnot have the old users name under line appearance.
If anyone has encountered this issue or have any suggestions please let me know.
AK
1 ACCEPTED SOLUTION
If running W7, and I believe
If running W7, and I believe it's the same for W8, delete the CSF folder from these 2 locations
%userprofile%\AppData\Local\Cisco\Unified Communications\Jabber
%userprofile%\AppData\Roaming\Cisco\Unified Communications\Jabber
java
if this helps, please rate
www.cisco.com/go/pdi
Have you tried deleting the
Have you tried deleting the Jabber cache??
java
Dear  Jaimewhere we can clear
Dear  Jaime
where we can clear cache??
C:\Users\abc\AppData\Local\Cisco\Unified Communications\Jabber\CSF
java
Apply following base filter
Apply following base filter to your jabber-config.xml file under directory section:
<BaseFilter>(&amp;(objectclass=user)(objectcategory=person)(!UserAccountControl:1.2.840.113556.1.4.803:=2)</BaseFilter>
54
