Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
image in cisco ip phones
Can we keep different images in Cisco IP phones for individual users in Cisco callmanager express 7.0 , for example if the user wants to keep his family members picture in the IP phone and that rest of the users cannot see .Please suggest....
Thanks in advance!
Nayeem
Re: image in cisco ip phones
If you were running CUCM then the Phone Designer Widget would allow you to do this.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6882/ps9156/at_a_glance_c45-487466.pdf
Unfortunately this product does not seem to be supported by CUCME.
Hopefully other forum members can come up with some suggestions.
Unfotunately since the List.xml is stored in the TFTP, which is the CME, anyone with the same phone model would see the picture. Also all the procedure to get the picture into the TFTP has to be done by the CME admin and not by the users.
You would need to upload the picture, go the phone, load the picture to the phone, delete the picture, repeat for next user who wants this.
If you were running CUCM phone designer would be the way.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
193
