Impact of resetting Route List
We're running CUCM 8.5.  I need to reset a route list, to add a new SIP router as a secondary outbound cube.
What's the impact on current calls/phones if I reset the route list during the day?
The new config has already been tested.
2 ACCEPTED SOLUTIONS
Resetting the route list does not affect calls  whatsoever because it doesn't reset the gateways. it only reinitializes the configuration that was loaded by Call manager.
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
As you are able to successfully test it in the lab, you can go ahead and perform the reset on the Prouction system as well, because the behavior of CUCM will remain the same.
Manish
Hi Bill,
If the call is already connected then it would not be dropped by a reset of the route list as it does not reset the gateways.
Manish
Thanks +5, my testing confirms this as well.
So just to confirm, I can reset a route list during production hours with no impact?
Manish
Br,
Nadeem
423
