06-03-2010 08:36 AM - edited 03-15-2019 11:05 PM
Good Morning,
We are currently in the process of migrationg from legacy pbx to IP. We have a mixed environement of phones. We want to move our switchboard off of the pbx to CUEAC. Is there a way to import a flat file directory into CUCM or CUEAC? The fil is a CSV file.
Liam
06-03-2010 08:47 AM
Liam,
I am not sure about CUEAC off of the top of my head. For CUCM, you can add users to the system using the Bulk Administration Tool (BAT). BAT can read a properly formatted .csv file and create or update users in bulk.
CUCM can also synchronize from a backend LDAP repository, which may be of interest to you.
HTH.
Bill
02-14-2012 11:58 AM
The only option with CUEAC today is to do a directory sync with the UCM, there is no option to import a directory from a csv file
