import/export config file
Im trying to export the config file from call manager v8.6 and import it to version 9.1.
I can export it without any errors but once I try to import it to 9.1 it gives me loads of errors.
I'm doing for the whole cucm configuration.
Is it because there are same fields that are different between this two versions?
I was trying to install call manager 8.6, import and then upgrade to 9.1.
Thanks in advance,
Chris
2 ACCEPTED SOLUTIONS
I am afraid it does not work that way. Yes, the file structure is quite different.
G.
Hall of Fame Super Silver
Take a DRS backup of your production system
Install lab as 8.6 in isolated lab as you will need to have the same hostname/ip address
restore from the DRS backup
change hostname and IP address at which point you can put it up on production network
upgrade to 9.1
That's all.
HTH,
Chris
G.
Ok,
So I have both ISO's. 8.6 and 9.1
If I install 8.6, import the config and then upgrade to 9.1? or the file to do the upgrade to 9.1 is a diffenret one from the brand new installation ISO?
Well you must be absolutely sure that the versions of CUCM where you exported and where you want to import to are the same.
Then you can download the upgrade image from cisco.com.
G.
Re: import/export config file
Hi Chris.
As Gergely correclty stated, (+5 P G) 9.1 has a quite different structure than 8.6
but if if you import an 8.6 config on another 8.6 than upgrade to 9.1 it should work.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks guys, will do the 8.6 and then upgrade!
VIP Super Bronze
May I ask why you are not doing the recommended DRS backup and restore? Why are you going down the import/export route?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
I want to keep the prodution version 8.6 up and running. The 9.1 is just for lab but want to have the same config on it
upgrade to 9.1
That's all.
HTH,
Chris
VIP Super Bronze
My thoughts exactly..Chris..Not sure why people want do import/export config. This is the second time soneone has mentioned it and  I find it a little strange..
271
