Community Member
Import Route Pattern or Translation Pattern
Hi.
I need import 150 route pattern or 150 translatio pattern to ccm 5.1. In Bat I don't see template to it. Are there same mode to import route pattern?
thanks
Hall of Fame Super Silver
Re: Import Route Pattern or Translation Pattern
There is no bulk import of these. The only way you can accomplish this is if you create a tool that will utilize AXL, I suggest you post your question on the developer forum.
Sorry, HTH
Chris
Community Member
Thanks!
328
