02-25-2009 01:37 PM - edited 03-15-2019 04:28 PM
Hi all,
Very important when designing ToIP solution !
Is there any method that allows us to have a same EM PIN and Voice Mail Password whithin a single ToIP infrastructure
Thansk in advance
kind regards,
Solved! Go to Solution.
02-26-2009 06:55 AM
all the info is pulled into the CUCM DB, including pwds. if you check the authentication then the pwd from cucm will be compared against the one in AD.
this is done to enforce authentication but if it's not enabled all the info is stored locally and an AD outage won't affect this
java
if this helps, please rate
02-25-2009 01:49 PM
you certainly can enable EM to be numeric only and use the same PIN for VM but the DBs are not connected at that level and changing one does not change the other, it's manually defined on each system.
java
02-25-2009 10:43 PM
This means that I can only import users from CCM except passwords that must be set locally ?
I think also that it is possible to synchronize with an AD and activate authentication so the passwords in this case are stored in the AD . do you confirm that ?
regards,
02-26-2009 06:55 AM
java
02-25-2009 01:56 PM
In addition to the previous info.
The PIN is to be used with any services you'll access through your IP phone
The password is to be used with any web interaction or third application
You can modify them from the user conf page
Wish this be helpful
