Importing into Personal Directory
Can I import an excel or csv file into my Personal Directory instead of entering each one? Where is it kept, on the SQL Server? I can't seem to find it in there, (which table?). Thanks in advance.
Re: Importing into Personal Directory
You can import entries by using the Cisco IP Phone Address Book Synchronizer found under Application -> Install Plugins in CCM admin. This product will only sync the Windows Address Book. Outlook Express uses the Windows Address Book, but Outlook uses the Personal Address Book. So, if you have contacts in Outlook, you will need to export them to a .csv, import them into the WAB and use the synchronizer to sync to your personal directory.
Hope this helps. If so, please rate the post.
Brandon
I saw this plugin but as you said it only synchronizes Windows Address Book. Our Address book is in Lotus notes. I guess I can probably export it out of Lotus Notes then import it to Outlook Express? Is there any other way of importing besides the synchronizer?
I developed an application for a German customer who is using Lotus Domino too.This application should be accesed through Services button on IP Phone This application queries Domino directory or Notes Personal Address Book via WebServices and displays results on IP phone. You can find a User Manual in german on my website http://www.arsnet.eu/workshop/iBOS20-Cisco-DE-pptA4.pdf . I can develop this Application in English too.
Regards, Robert
IP Phone Address Book Synchronizer is not in my CCM Admin and I can't find it in the Cisco software download offerings. Any suggestions as to where to find?
Thanks.
Gold
Try using the following link and let me know if it works:
https:///plugins/TabSyncInstall.exe
Yes, thanks...it was h1ding in plain sight.
Nevermind....opened my good eye and found it right where it belongs.
454
