Importing unity & jabber users from AD
1.The scenario totaly 200 active devices  are registered to CUCM ,CUCM users already part of AD,i need to integerate AD user to acess Cisco Unity for voicemail functionality will it be possible?
Should i create the enduser in CUCM & import to unity
which is the best practise?
2.Scenario there are 2 BE6K server one with high density  & another Medium density
Medium density server is dedicately  for redudancy purpose
In high denstity planned to install PUB,UC,IM,UCCX
In Medium density server planned to install only SUB
My question can i have redudancy for UC,IM,UCCX in Medium density server? required any additional licenses?
VIP Purple
Hi Siva,
To answer your second query :
Can I mix Medium and High Density servers in a deployment?
A. Yes, any mix of BE6000 server types is permitted in a deployment, but in such case the total number of
devices supported is limited to 1200.
Can I order a solution with redundant servers?
A. Yes, order as many Medium and High Density servers as required. User licensing ordered with R-CBE6K-K9
will activate services across multiple servers. No specific licenses are required to enable redundancy for
Cisco Unified Communication Manager, Cisco Unity Connection, and Cisco Unified Presence.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps11369/qa_c67-703226.html
regds,
aman
Hi Aman,
Any idea about importing users from AD ?
Re: Importing unity & jabber users from AD
Regarding scenario 1 , yes you can create voicemail profile on cups and assign it to the user settings
You can use LDAP for pretty much everything you ask and that way there's no dependency between the UC products.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
86
