In CUCM 6/7, is it possible to bring up a primary node
kinwai
in a cluster when the primary node(publisher) fails without restoring via DRS?
Just wondering if is it possible at all?
Let's say by using some dbreplication command to replicate the subscriber's data to rebuilt the publisher's database.
Rob Huffman
Hi Kinwai,
CCM 6.x and 7.x has the same design considerations as before when it comes to the Single Publisher with multiple Subscriber setup. My understanding is that Cisco is working on a method to promote a Sub to Pub for Disaster recovery purposes, but this has not yet been released. Soon I hope :)
Hope this helps!
Rob
Rob Huffman
Hi Kinwai,
Hope this helps!
Rob
Hi Rob,
thanks a lot! Hopefully it will be possible soon!
I'm trying out the new CUCM 7 beta from cisco, i found a lot of new commands especially in "utils dbreplication",so just wondering if it's possible now.
Cheers,
kinwai
