01-09-2008 11:19 AM - edited 03-15-2019 08:07 AM
Are there any options for conference phones that will run on in-line power?
01-09-2008 11:27 AM
I think the new 7937G Conference stations will support PoE.
Manu
01-09-2008 01:39 PM
Thanks Manu!
Does anyone know if the 7936 or 7935 would run on in-line power?
01-09-2008 04:48 PM
Hi Ryan,
These units require 30 volts so I guess no standard PoE :) What I am guessing is that you would like to eliminate to "rats nest" of wiring that these rely on for power.
We have used the power module in the wiring closet and then standard Cat5E or Cat6 to the phone but only up to about 100 feet so far. This does make the setup much more aesthetically pleasing.
Here are the specs;
Cable Specifications
Keyed RJ-45 plug for the 25-ft. CAT 5 cable connection on the bottom of the IP Conference Station unit
Keyed RJ-45 plug for the 25-ft. CAT 5 cable connection on the PIM
RJ-45 plug for the 6-ft. CAT 5 cable connection on the PIM
30-volt power connector for power connection on the PIM
From this doc;
Hope this helps!
Rob
01-09-2008 08:32 PM
AS stated above 7937 supports inline power
7935&36 needs special adapter
01-10-2008 06:16 AM
All of this helps---Thanks guys!
Is there a diagram or something that would show the phones that work with in-line power?
I guess I am looking for the phones that would work almost plug-and-play versus the phones that would require a special adapter (ie 7935 and 7936).
01-10-2008 06:28 AM
Hi Ryan,
This is the best doc that I have seen that details the PoE requirements for the various IP Phone models.
Power over Ethernet (PoE) Power Requirements FAQ
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00808996f3.shtml
Hope this helps and best of luck!
Rob
