in Unity, xfer the call to different destination according to the time????
How to make it in Unity according to the belowing ,
On hour(9am-5pm)call 2003 noan/busy forward to 4085158801
after hour, call 2003 noan/busy can leave msg
pls give me some advice or useful URL for reference.
1 ACCEPTED SOLUTION
Re: in Unity, xfer the call to different destination according t
first of all, exactly what do you mean by transfer??
call reaches phone, then goes to unity and follows X behavior??
or someone calls unity and then someone dials the DN for that phone??
the 1st behavior can be easily achieved with CUCM TOD, the other way is a schedule and std and closed greeting
java
if this helps, please rate
java
www.cisco.com/go/pdi
If you are running unity connection, you can use Personal Call transfer rules.
More info can be found here :
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user/guide/pctr/7xcucugpctrx.html
Kind Regards,
Jeroen
PS : Please rate the ost if you find it usefull.
So how about Unity??
java
java
113
