08-28-2008 07:13 AM - edited 03-15-2019 12:54 PM
I have CCME 4.0(3) on routeur 2801 and
I want to redirect the inbound calls from PSTN to four IP Phones. So when we call from the PSTN the 4 Ip Phones Ring.
I know that it is possible with connection PLAR on voice port but it support only one ephone-dn
Thankyou for your help
Malek
08-28-2008 07:15 AM
Hunt Groups
Hunt groups allow incoming calls to a specific number (pilot number) to be directed to a defined group of extension numbers.
Incoming calls are redirected from the pilot number to the first extension number as defined by the configuration. If the first number is busy or does not answer, the call is redirected to the next phone in the list. A call continues to be redirected on busy or no answer from number to number in the list until it is answered or until the call reaches the number that is defined as the final number.
java
if this helps, please rate
08-28-2008 07:15 AM
Do you want the 4 phones to ring simultaneously, or hunt from one to another?
08-28-2008 07:17 AM
hello,
you can do so by configuring the hunt group and the time between each phone must be very low.
Driss
08-28-2008 08:17 AM
Thanks evrybody for your help.
CCME 4.0 can not support parralel ring, but it support sequentiel and i tune timout to 15s
08-28-2008 08:19 AM
in case you're interested CME 4.3/7.0 does support it now
java
08-28-2008 08:32 AM
Please can u tell me witch IOS version embeed CCME 4.3 for 2801, I am looking for this version with software advisor but the recent one is 4.0.3
08-28-2008 08:40 AM
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Cisco Unified CME 7.0/4.3 Supported Firmware, Platforms, Memory, and Voice Products
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme43spc.htm
java
