02-09-2010 07:23 AM - edited 03-18-2019 11:04 AM
All,
I am trying to redirect an inbound call at the gateway level on an h323 gateway. The calls come in on a single PRI. What I am trying to do now is use two different inbound dial-peers with the same incoming called-number and the max-conn command. This works fine in the outbound direction however I cant seem to get the call to hunt to the next, lower preference dial-peer for inbound calls. Any ideas on how to get this to work? Thanks for looking!
dial-peer voice 112 pots
max-conn 1
incoming called-number 8165551212
direct-inward-dial
dial-peer voice 113 pots
huntstop
preference 1
max-conn 2
direct-inward-dial
02-09-2010 07:31 AM
On first view i would expect this to work.Have you ran a debug voip dialpeer to see whats going
on?
cheers
mark
02-15-2010 08:35 AM
Any thoughts on this? I am truley stumped. Thanks again for looking.
02-09-2010 08:50 AM
Id do a debug on the dial peer to see whats going on.
I assume when you tested this, you have one call pegged up and its using dial peer 112. Then create a second call and then it should hit dial peer 113.
If it does not, the debug dial peer will show this.
02-09-2010 12:40 PM
Thank you both for the reply. Yes we did busy out the first dial-peer. We did look at the 'debug voip dialpeer' and we see these lines in particular:
Feb 9 14:13:14: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 112
Feb 9 14:13:14: ISDN Se0/1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8473
Cause i = 0x80AF - Resource unavailable, unspecified
I guess I just assumed it would hunt to the next dial-peer at this point. Any ideas why its not? I have attached the full result of the debug in case you are interested. Thanks for the help! Nathan
