Inbound call blocking based on ANI
Has anyone ever had to try and block calls from one specific outside caller with one specific ANI to one internal user?
Re: Inbound call blocking based on ANI
If you're using H.323 on the gateway, one way to do this is with a voice translation rule. You can use the "reject" keyword when creating the rule. Take a look at the following link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Hope this helps. If so, please rate the post.
Brandon
Hi !
Thanks for the response! No, all I have to work with is ccm 4.1(3) and mgcp gateways on both 6608's and cmm mods. :(
Matt
Matt,
There's no way to do this with MGCP that I'm aware of.
Brandon
hi!
you know, i read this document and it looks like the only way to reject calls is based on the dialed number. I want to know if there is anyway to block calls from a specific number... ???
thanks,
matt
Yes, in the translation profile, you can use "translate calling" along with the "reject" keyword in the rule to block callling numbers.
Brandon
255
