Inbound call problem
I have a voice gateway with a T1 line. A toll free number is associated with it.
All was working fine till yesterday and i am not able to receive any inbound calls on the number. Outbound calls are still working fine
following is the configuration on my VG
voice-port 2/0:23
connection plar 8901
voice-port 3/0:23
dial-peer voice 5 voip
destination-pattern 8901
session target ipv4:172.20.33.5
dtmf-relay h245-alphanumeric
ip precedence 5
dial-peer voice 6 pots
destination-pattern 9T
port 2/0:23
dial-peer voice 7 pots
port 3/0:23
interface Serial2/0:23
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
interface Serial3/0:23
no ip address
encapsulation hdlc
no cdp enable
Thanks in advance
Narayan
Community Member
Re: Inbound call problem
Narayan
Can you actually see the 800 number hitting the gateway?
Do a debug isdn q931 and see if the number gets routed properly by the provider. If all was working fine, then stop working I will work my way from the outside in.
Armando
Hi Armando,
It got solved. The JTAPI subsystem was inactive in the customer response application.
Once the engine was restarted, it got solved.
Narayan
104
