11-08-2010 12:40 PM - edited 03-16-2019 01:48 AM
I have CM 6 and use an MGCP gateway with a PRI. I provide caller id that includes name and number of our inbound calls. We now have a compliance line that has to be anonymous. I do I selectively block caller id from callers calling into my compliance hot line. Or maybe change the caller id to a fake number? Any ideas would be appreciated.
Gary Asher
11-08-2010 01:04 PM
Disregard this post
11-08-2010 01:09 PM
This is asked over and over again, and the answer would have been relealed with a simple search.
Since you are using MGCP, there is no way whatsoever to do that.
It is instead possible when using H.323 or SIP.
11-08-2010 01:21 PM
Thank you for your reply. By the way I did search and found many pages of post. I looked through them and did not find anything with blocking selective inbound caller id.
Thanks for the quick reply.
11-08-2010 01:43 PM
Basically with MGCP you cannot route on calling number, meaning no anonymous screening, no caller hotlist, no geographical call routing, etc.
All that and more is possible with H.323 or SIP because the VG retains intelligence.
Please remember to rate useful posts clicking on the stars below.
