Community Member
inbound calls error on FXO
Hi Voice Team,
All the sites was working normally.
I have 3 sites com the same problem:
- They are not receiving calls by FXO.
But all site can to make outbound calls.
Can you help me please???
For example: Bellow are FXO state of the 2 sites.
SITE A
GW_SESCUNIAO#sh voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/1/2           --  fxo-ls      up    dorm idle     on-hook  y
0/1/3           --  fxo-ls      up    dorm idle     on-hook  y
SITE B
GW_SESCTOLEDO#sh voice port summary
                                          IN       OUT
0/0/0          --  fxo-ls      up    dorm idle     on-hook  y
0/0/1          --  fxo-ls      up    dorm idle     on-hook  y
0/0/2          --  fxo-ls      up    dorm idle     on-hook  y
0/0/3          --  fxo-ls      up    dorm idle     on-hook  y
thanks
Hall of Fame Super Gold
Re: inbound calls error on FXO
Likely configuration problem. You are not telling anything about, so it's everybody guess.
Community Member
The environment is:
IP phone <<>> CME <<>> PSTN
The command bellow show a inbound call (A2900A0000) originated by a mobile phone and this call was completed with sucess, but when the source number is a local number the call is not completed.
GW_SESCTOLEDO#sh voice call status
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0x42B      20DB 0x64F71044 0/0/2            0/1:3   A2900A0000 g711ulaw  0/20011
0x42C      20E1 0x65CEB590 50/0/1.0                *A2900A0000 g711ulaw  20011/0
0x42F      20F0 0x65BFE7B4 50/0/5.0                 030546100  g711ulaw  20005/101
0x430      20F0 0x655DF21C 0/0/3            0/1:4  *030546100  g711ulaw  101/20005
.. Config... traces..
All that is missing.
Would you be able to help when presented with skimpy information ?
Community Member
The File debug was attached. (sh tech, debug voice ccapi inout, debug voip vtsp all, show voice port summary, show voice call status, show voice call summary)
In the files debugs we can to see that the call is forwarded for the DN 2690, but the source user has the busy tone.
The line that receive all calls is 42 3522-4332.
thanks.
Community Member
Thanks all.
The problem was solved.
The ephone-hunt configuration was the case.
att.
264
