inbound calls via sip do not go to voicemail, inside calls do
When receiving inbound calls via our sip trunk the calls will not roll over to voicemail, the call just gets dropped.
If we call the voicemail pilots internally, or call each other and dont answer the calls go to voicemail correctly.
researching this it appears to be something with the dspfarm and transcoding, but I am still very new to this and not sure how this should be configured.
Here is our config and our hardware. I have two pvdm modules installed. when running show dspfarm i get that its down, not sure how/where to noshut these, or if these are our problem.
dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
router1#sh run
Building configuration...
Current configuration : 5430 bytes
! Last configuration change at 13:42:23 UTC Tue Sep 9 2014
! NVRAM config last updated at 13:35:37 UTC Tue Sep 9 2014
version 15.1
hostname router1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.1.100.1 10.1.100.50
ip dhcp excluded-address 10.1.1.1 10.1.1.49
ip dhcp pool Data
 network 10.1.1.0 255.255.255.0
 dns-server 10.1.1.20
 option 150 ip 10.1.1.1
 default-router 10.1.1.1
ip domain name legacy.local
ip name-server 8.8.8.8
no ipv6 cef
voice service voip
 ip address trusted list
  ipv4 214.115.69.0 255.255.255.0
  ipv4 70.167.153.130 255.255.255.255
  ipv4 24.240.233.212 255.255.255.255
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.3
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
  h225 h245-address on-connect
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
 codec preference 3 g711alaw
voice translation-rule 1
 rule 1 /^9/ //
voice translation-rule 2
 rule 1 /19729965165/ /102/
voice translation-profile inboundprofile
 translate called 2
voice-card 0
license udi pid CISCO2821 sn xx
redundancy
interface GigabitEthernet0/0
 ip address 10.1.1.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex full
 speed 100
interface GigabitEthernet0/1
 ip address 71.170.37.123 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 h323-gateway voip bind srcaddr 71.170.37.123
interface Service-Engine1/0
 ip unnumbered GigabitEthernet0/0
 service-module ip address 10.1.1.2 255.255.255.0
 service-module ip default-gateway 10.1.1.1
ip default-gateway 71.170.37.1
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/GUI
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 2 interface GigabitEthernet0/1 overload
ip nat inside source list 3 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.1.1.22 25 71.170.37.123 25 extendable
ip nat inside source static tcp 10.1.1.22 443 71.170.37.123 443 extendable
ip nat inside source static tcp 10.1.1.20 1723 71.170.37.123 1723 extendable
ip route 0.0.0.0 0.0.0.0 71.170.37.1
ip route 10.1.1.2 255.255.255.255 Service-Engine1/0
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.100.0 0.0.0.255
access-list 3 permit 10.1.200.0 0.0.0.255
tftp-server flash:/IP_Phones/7940_7960/Sccp/P0030801SR02.bin
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
dial-peer voice 2 voip
 destination-pattern 1[2-9].........
 translate-outgoing called 1
 session protocol sipv2
 session target dns:sip.flowroute.com
 voice-class codec 1
 dtmf-relay rtp-nte digit-drop
 dtmf-interworking standard
dial-peer voice 3 voip
 destination-pattern 2...
 session target ipv4:10.1.1.2
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 4 voip
 translation-profile incoming inboundprofile
 session target sip-server
 incoming called-number .%
sip-ua
 authentication username xx password 7 xx realm sip.flowroute.com
 calling-info pstn-to-sip from number set 19729965165
 no remote-party-id
 registrar dns:sip.flowroute.com expires 3600
telephony-service
 video
  maximum bit-rate 256
 max-ephones 58
 max-dn 192
 ip source-address 10.1.1.1 port 2000
 ip qos dscp af31 signal
 service phone videoCapability 1
 system message Legacy Vinyl Windows
 cnf-file perphone
 load 7960-7940 P0030801SR02
 time-zone 8
 voicemail 2000
 max-conferences 8 gain -6
 dn-webedit
 time-webedit
 transfer-system full-consult
 secondary-dialtone 9
 create cnf-files version-stamp 7960 Sep 03 2014 19:37:20
ephone-dn  1  dual-line
 number 110
 description Heath 110
 name Heath
 call-forward busy 2000
 call-forward noan 2000 timeout 10
ephone-dn  2  dual-line
 number 102
 description David
 name David
ephone-dn  98
 number 8001....
 mwi off
ephone-dn  99
 number 8000....
 mwi on
ephone  1
 device-security-mode none
 mac-address 9048.9A8C.25A5
 type CIPC
 button  1:1
ephone  2
 mac-address 0011.920E.11B7
 type 7940
 button  1:1
ephone  3
 mac-address 000E.D7D8.785C
 type 7940
 button  1:2
line con 0
line aux 0
line 66
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server pool.ntp.org
ntp server 0.us.pool.ntp.org
ntp server 2.us.pool.ntp.org
end
router1#
router1#sh diag
Slot 0:
        C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 5d00h ago
        Onboard VPN             : v2.3.3
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC10314QF6
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26921-02
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20060812
        Chassis Serial Number    : FTX1034A125
        Chassis MAC Address      : 0018.ba48.90a0
        MAC Address block size   : 32
        CLEI Code                : COM3D00BRA
        Product (FRU) Number     : CISCO2821
        Part Number              : 73-8853-04
        Version Identifier       : V03
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 30 33 31 34 51 46 36 40
          0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 02 42 41 30
          0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 1A 8C C2 8B 46 54 58 31 30 33 34
          0x40: 41 31 32 35 C3 06 00 18 BA 48 90 A0 43 00 20 C6
          0x50: 8A 43 4F 4D 33 44 30 30 42 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
          0x70: 04 89 56 30 33 20 D9 02 40 C1 FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
        Hardware Revision        : 4.0
        Part Number              : 73-8538-05
        Board Revision           : B0
        Fab Version              : 04
        PCB Serial Number        : FOC12121LQ5
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM2-16
        Version Identifier       : V01
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 42 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 31 32
          0x20: 31 4C 51 35 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
          0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC1431212Y
        RMA History              : 00
        Processor type           : 00
          0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 43 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 34 33 31
          0x20: 32 31 32 59 03 00 81 00 00 00 00 04 00 09 00 CB
        WIC Slot 0:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-02
        Board Revision           : A0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC10333XN8
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        CLEI Code                : CNUIAPRAAA
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 02
          0x10: 42 41 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 30 33 33 33 58 4E 38 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
        WIC Slot 1:
        FXS Voice daughter card (4 port)
        Part Number              : 73-6918-01
        Board Revision           : 03
        Fab Version              : 01
        PCB Serial Number        : QuadDID-FXS
        RMA History              : 00
        Top Assy. Part Number    : 800-17016-01
        Connector Type           : 01
        Product (FRU) Number     : VIC-4FXS/DID=
          0x00: 04 FF 40 00 3A 41 01 00 82 49 1B 06 01 42 30 33
          0x10: 80 00 00 00 00 02 01 C1 8B 51 75 61 64 44 49 44
          0x20: 2D 46 58 53 03 00 81 00 00 00 00 04 00 C0 46 03
          0x30: 20 00 42 78 01 05 01 FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
        Service Engine Port adapter, 1 port
        Top Assy. Part Number    : 800-21693-07
        Board Revision           : AO
        Deviation Number         : 93822
        Fab Version              : 02
        PCB Serial Number        : FOC115240BM
        RMA History              : 00
        Fab Part Number          : 28-5683-02
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        Field Diagnostics Data   : 00 00 00 00 00 00 00 00
        Product (FRU) Number     : NM-CUE
          0x00: 04 FF 40 03 AA 41 01 00 C0 46 03 20 00 54 BD 07
          0x10: 42 41 4F 88 00 01 6E 7E 02 02 C1 8B 46 4F 43 31
          0x20: 31 35 32 34 30 42 4D 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 16 33 02 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 89 56 30 33 00 CB 86
          0x50: 4E 4D 2D 43 55 45 FF FF FF FF FF FF FF FF FF FF
        40GB IDE Disc Daughter Card
        Top Assy. Part Number    : 800-27583-02
        Board Revision           : A0
        Fab Version              : 01
        PCB Serial Number        : FOC11500M7G
        RMA History              : 00
        Fab Part Number          : 28-5685-01
          0x00: 04 FF 40 03 D8 41 01 00 C0 46 03 20 00 6B BF 02
          0x10: 42 41 30 80 00 00 00 00 02 01 C1 8B 46 4F 43 31
          0x20: 31 35 30 30 4D 37 47 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 16 35 01 C4 08 00 00 00 00 00 00 00 00 C5
          0x40: 08 00 00 00 00 00 00 00 00 88 00 00 00 00 FF FF
router1#
2 ACCEPTED SOLUTIONS
VIP Gold
Assuming call agent it CME.
Assuming call agent it CME..below is the example for transcoder configuration..
voice-card 0
dsp services dspfarm
sccp local gig0/0 ------------Interface may be different from gig0/0
sccp ccm 10.xx.xx.xx identifier 1 version 7.0   -----(cme ip address)
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.10 --------use specific interface
associate ccm 1 priority 1
associate profile 1 register transcoder
dspfarm profile 1 transcoder
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2------------------------------------define maximun session as needed.
associate application SCCP
telephony-service
sdspfarm units 5
sdspfarm tag 1 transcoder
Hope this helps you to configure dsp resources for these calls.
Suresh
Please try this Router(config
Please try this
Router(config)#voice service voip
Router(conf-voi-serv)#no supplementary-service sip refer
and check the AA transfer works?
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html#call-transfer
//Suresh Please rate all the useful posts.
VIP Gold
voice-card 0
sccp
sccp ccm group 1
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
telephony-service
sdspfarm units 5
Suresh
Thank you for your help! This
This got the dspfarm up, but calls are still not able to go to voicemail or the AA from external. The call just gets dropped. Internal is fine.
Are there any logs/debugs I can run that can assist me in figuring out why this is happening?
VIP Gold
Can you try to give "sip"
Can you try to give "sip" command under 'voice service voip' and then try.
If no success then please attach below logs for a failed call..
debug voip ccapi inout
debug ccsip messages
Suresh
after issuing the sip command
after issuing the sip command no change. Here is a log of a failed call. It should go into the AA which is 2001
router1#
Sep 10 15:06:10.801: %SYS-5-CONFIG_I: Configured from console by console
router1#debug voip ccapi inout
voip ccapi inout debugging is on
router1#debug ccsip messages
SIP Call messages tracing is enabled
router1#
Sep 10 15:07:30.211: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:71.170.37.123:49832 SIP/2.0
Max-Forwards: 10
Record-Route: <sip:216.115.69.144;lr>
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKe19c.f637b7f439e1a88de4e452df01989645.0
Via: SIP/2.0/UDP 216.115.69.131:5060;branch=0
Route: <sip:216.115.69.144;lr;received='sip:71.170.37.123:49832'>
To: sip:71.170.37.123:49832
Call-ID: fb224c2-6cad7b28-40e12f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 10 15:07:30.215: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK02ae.eb8d0370e4360cdcfafbd5fd78fa91d4.0
Call-ID: fb224c2-7cad7b28-40e12f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 10 15:07:30.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKc351.857a93727aa45ace9aaf6158de3e0358.0
Call-ID: fb224c2-8cad7b28-40e12f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 10 15:07:30.227: //1150/04BFBA7784D1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKe19c.f637b7f439e1a88de4e452df01989645.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=9A090C-1C27
Date: Wed, 10 Sep 2014 15:07:30 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 8587 1616 IN IP4 71.170.37.123
s=SIP Call
c=IN IP4 71.170.37.123
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
Sep 10 15:07:30.227: //1151/04C0569F84D2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK02ae.eb8d0370e4360cdcfafbd5fd78fa91d4.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=9A0910-551
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 4095 6328 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 10 15:07:30.227: //1152/04C0F35F84D3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKc351.857a93727aa45ace9aaf6158de3e0358.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=9A0914-205A
CSeq: 1 OPTIONS
Content-Length: 455
v=0
o=CiscoSystemsSIP-GW-UserAgent 1048 501 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 10 15:07:30.471: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:19729965165@71.170.37.123 SIP/2.0
From: "WIRELESS CALLER" <sip:+12145579949@fl.gg>;tag=gK041d50a4
Max-Forwards: 66
Record-Route: <sip:216.115.69.132;lr>
To: <sip:+19729965165@fl.gg>
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK89dd.2ff610ef82ad68342936093cd6a031ba.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK89dd.55fb673aeb85605cfdf9a5e36f87985f.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK89dd.9e23bc1049532acc92130ec10a668af3.0
Via: SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK04Bc4f33c87e12ae6eb
Call-ID: 688172197_103847321@4.55.17.35
CSeq: 4756 INVITE
Contact: <sip:+12145579949@4.55.17.35:5060>
Content-Length:  216
P-Asserted-Identity: "WIRELESS CALLER" <sip:+12145579949@fl.gg>
v=0
o=- 25630 32699 IN IP4 4.55.17.2
s=-
c=IN IP4 4.55.17.2
t=0 0
m=audio 18536 RTP/AVP 0 8 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=maxptime:20
Sep 10 15:07:30.479: //-1/04E802BA84D4/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=+12145579949
   ----- ccCallInfo IE subfields -----
   cisco-ani=+12145579949
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=19729965165
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Sep 10 15:07:30.479: //-1/04E802BA84D4/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49FC41F0, Call Info(
   Calling Number=+12145579949,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=19729965165(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=4, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1153
Sep 10 15:07:30.479: //-1/04E802BA84D4/CCAPI/ccCheckClipClir:
   In: Calling Number=+12145579949(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Sep 10 15:07:30.483: //-1/04E802BA84D4/CCAPI/ccCheckClipClir:
   Out: Calling Number=+12145579949(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Sep 10 15:07:30.483: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 15:07:30.483: :cc_get_feature_vsa malloc success
Sep 10 15:07:30.483:  cc_get_feature_vsa count is 1
Sep 10 15:07:30.483: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633792,feature_id:17
Sep 10 15:07:30.483: //1153/04E802BA84D4/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=+12145579949(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=19729965165(TON=Unknown, NPI=Unknown))
Sep 10 15:07:30.483: //1153/04E802BA84D4/CCAPI/cc_process_call_setup_ind:
   Event=0x4B198F30
Sep 10 15:07:30.483: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 19729965165
Sep 10 15:07:30.483: //1153/04E802BA84D4/CCAPI/ccCallSetContext:
   Context=0x4E12E1F0
   >>>>CCAPI handed cid 1153 with tag 4 to app "_ManagedAppProcess_Default"
Sep 10 15:07:30.487: //1153/04E802BA84D4/CCAPI/ccCallProceeding:
Sep 10 15:07:30.487: //1153/04E802BA84D4/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3, Params=0x4E12F700, Progress Indication=NULL(0)
Sep 10 15:07:30.487: //1153/04E802BA84D4/CCAPI/ccCheckClipClir:
   Destination Pattern=2..., Called Number=2001, Digit Strip=FALSE
   Called Number=2001(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=WIRELESS CALLER
   Account Number=+12145579949, Final Destination Flag=TRUE,
   Guid=04E802BA-3833-11E4-84D4-A4D202FD5342, Outgoing Dial-peer=3
Sep 10 15:07:30.487: //1153/04E802BA84D4/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 10 15:07:30.487: //1153/04E802BA84D4/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49FC41F0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=+12145579949,(Calling Name=WIRELESS CALLER)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Sep 10 15:07:30.491: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 15:07:30.491: :cc_get_feature_vsa malloc success
Sep 10 15:07:30.491:  cc_get_feature_vsa count is 2
Sep 10 15:07:30.491: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633344,feature_id:18
Sep 10 15:07:30.491: //1154/04E802BA84D4/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Sep 10 15:07:30.491: //1154/04E802BA84D4/CCAPI/ccCallSetContext:
   Context=0x4E12F6B0
Sep 10 15:07:30.491: //1153/04E802BA84D4/CCAPI/ccSaveDialpeerTag:
Sep 10 15:07:30.491: //1154/04E802BA84D4/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x49FC41F0, Call Id=1154
Sep 10 15:07:30.495: //1154/04E802BA84D4/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Sep 10 15:07:30.495: //1153/04E802BA84D4/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Sep 10 15:07:30.495: //1154/04E802BA84D4/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=1154
Sep 10 15:07:30.495: //1154/04E802BA84D4/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Sep 10 15:07:30.495: //1154/04E802BA84D4/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x49FC41F0, Tag=0x0, Call Id=1154,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Sep 10 15:07:30.495: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 10 15:07:30.495: :cc_free_feature_vsa freeing 4C54E9F8
Sep 10 15:07:30.495:  vsacount in free is 1
Sep 10 15:07:30.499: //1153/04E802BA84D4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK89dd.2ff610ef82ad68342936093cd6a031ba.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK89dd.55fb673aeb85605cfdf9a5e36f87985f.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bK89dd.9e23bc1049532acc92130ec10a668af3.0,SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK04Bc4f33c87e12ae6eb
CSeq: 4756 INVITE
Content-Length: 0
Sep 10 15:07:30.499: //1153/04E802BA84D4/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Sep 10 15:07:30.503: //1153/04E802BA84D4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:+19729965165@fl.gg>;tag=9A0A30-F60
CSeq: 4756 INVITE
Reason: Q.850;cause=47
Content-Length: 0
Sep 10 15:07:30.543: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:19729965165@71.170.37.123 SIP/2.0
Max-Forwards: 66
CSeq: 4756 ACK
Content-Length: 0
Sep 10 15:07:30.543: //1153/04E802BA84D4/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49FC41F0, Tag=0x0, Call Id=1153,
Sep 10 15:07:30.543: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 10 15:07:30.543: :cc_free_feature_vsa freeing 4C54EBB8
Sep 10 15:07:30.547:  vsacount in free is 0
Sep 10 15:07:30.767: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: "WIRELESS CALLER" <sip:+12145579949@fl.gg>;tag=gK041d5783
Max-Forward: 68
Record-Route: <sip:70.167.153.134;lr>
To: <sip:+19729965165@flowroute.com>
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK963a.00d08b2f9528b4b28dae1241fcf8e248.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK963a.3e8bb855f3eb68f4b63841f68bffcee7.1
Via: SIP/2.0/UDP 70.167.153.134;branch=z9hG4bK963a.425b4e061344703cc9503eedd18d50c9.0
Via: SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK04Bc4fb7f375fb13ab4
Call-ID: 688172200_70234078@4.55.17.35
CSeq: 401 INVITE
Max-Forwards: 96
Content-Length:  215
v=0
o=- 9057 11814 IN IP4 4.55.17.2
s=-
c=IN IP4 4.55.17.2
t=0 0
m=audio 19680 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=maxptime:20
Sep 10 15:07:30.775: //-1/0514901584DA/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=19729965165
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 10 15:07:30.775: //-1/0514901584DA/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1155
Sep 10 15:07:30.775: //-1/0514901584DA/CCAPI/ccCheckClipClir:
Sep 10 15:07:30.775: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 15:07:30.779: :cc_get_feature_vsa malloc success
Sep 10 15:07:30.779: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 15:07:30.779:  cc_get_feature_vsa count is 1
Sep 10 15:07:30.779: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633792,feature_id:19
Sep 10 15:07:30.779: //1155/0514901584DA/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Sep 10 15:07:30.779: //1155/0514901584DA/CCAPI/cc_process_call_setup_ind:
   Event=0x4B198F30
Sep 10 15:07:30.779: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Sep 10 15:07:30.779: //1155/0514901584DA/CCAPI/ccCallSetContext:
   Context=0x4E130B70
   >>>>CCAPI handed cid 1155 with tag 4 to app "_ManagedAppProcess_Default"
Sep 10 15:07:30.779: //1155/0514901584DA/CCAPI/ccCallProceeding:
Sep 10 15:07:30.783: //1155/0514901584DA/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4E132080, Progress Indication=NULL(0)
Sep 10 15:07:30.783: //1155/0514901584DA/CCAPI/ccCheckClipClir:
   Guid=05149015-3833-11E4-84DA-A4D202FD5342, Outgoing Dial-peer=3
Sep 10 15:07:30.783: //1155/0514901584DA/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 10 15:07:30.783: //1155/0514901584DA/CCAPI/ccIFCallSetupRequestPrivate:
Sep 10 15:07:30.787: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 10 15:07:30.787: :cc_get_feature_vsa malloc success
Sep 10 15:07:30.787:  cc_get_feature_vsa count is 2
Sep 10 15:07:30.787: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633344,feature_id:20
Sep 10 15:07:30.787: //1156/0514901584DA/CCAPI/ccIFCallSetupRequestPrivate:
Sep 10 15:07:30.787: //1156/0514901584DA/CCAPI/ccCallSetContext:
   Context=0x4E132030
Sep 10 15:07:30.787: //1155/0514901584DA/CCAPI/ccSaveDialpeerTag:
Sep 10 15:07:30.787: //1156/0514901584DA/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x49FC41F0, Call Id=1156
Sep 10 15:07:30.791: //1156/0514901584DA/CCAPI/cc_api_call_disconnected:
Sep 10 15:07:30.791: //1155/0514901584DA/CCAPI/ccCallReleaseResources:
Sep 10 15:07:30.791: //1156/0514901584DA/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=1156
Sep 10 15:07:30.791: //1156/0514901584DA/CCAPI/ccCallDisconnect:
Sep 10 15:07:30.791: //1156/0514901584DA/CCAPI/cc_api_call_disconnect_done:
   Disposition=-11, Interface=0x49FC41F0, Tag=0x0, Call Id=1156,
Sep 10 15:07:30.791: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 10 15:07:30.791: :cc_free_feature_vsa freeing 4C54E9F8
Sep 10 15:07:30.791:  vsacount in free is 1
Sep 10 15:07:30.795: //1155/0514901584DA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK963a.00d08b2f9528b4b28dae1241fcf8e248.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bK963a.3e8bb855f3eb68f4b63841f68bffcee7.1,SIP/2.0/UDP 70.167.153.134;branch=z9hG4bK963a.425b4e061344703cc9503eedd18d50c9.0,SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK04Bc4fb7f375fb13ab4
CSeq: 401 INVITE
Content-Length: 0
Sep 10 15:07:30.795: //1155/0514901584DA/CCAPI/ccCallDisconnect:
Sep 10 15:07:30.799: //1155/0514901584DA/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:+19729965165@flowroute.com>;tag=9A0B58-1532
CSeq: 401 INVITE
Content-Length: 0
Sep 10 15:07:30.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 401 ACK
Max-Forwards: 96
Content-Length: 0
Sep 10 15:07:30.839: //1155/0514901584DA/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49FC41F0, Tag=0x0, Call Id=1155,
Sep 10 15:07:30.839: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 10 15:07:30.839: :cc_free_feature_vsa freeing 4C54EBB8
Sep 10 15:07:30.839:  vsacount in free is 0
VIP Gold
Call is disconnecting with
Call is disconnecting with reason code 47, which says Internal resource allocation failure...
Typical scenarios include:
• Out of memory
• Internal access to the TCP socket is unavailable
Please check ACL.
Suresh
Hi.Code 47 also indicate a
Hi.
Code 47 also indicate a codec mismatch.
I see that you are negotiating g729 with your provider.
Just to make sure, try to change dialpeer 2 removing voice class codec 1 and adding codec g711ulaw and see if it works.
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
making those changes to dial
making those changes to dial peer 2 did not help
I added codec g711ulaw to dial peer 4 (the incoming from sip trunk) and it went into the auto attendant, but when i dialed 110 to be transferred to extension 110 it dropped the call.
when i changed the inbound translation rule to make the inbound calls go to extension 110 the call rings, but when it tries to roll over to voicemail it gets dropped
when i changed the inbound translation rule to make the inbound calls directly to the voicemail app the voicemail system answered.
so we are getting a little farther.
Hi.Under voice service voip
Hi.
Under voice service voip try to add
no supplementary-service sip moved-temporarily
Carlo
that fixed the calls to
that fixed the calls to voicemail!!
now the only calls dropping are the calls from the autoattendant to extensions.
Hi.Please a debug ccsip
Hi.
Please a debug ccsip messages while call moves from AA to Extension.
Add also a debug voip ccapi inout during the same moment.
Carlo
Here you go!router1#debug
Here you go!
router1#
Sep 12 14:55:07.077: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK95a.79dcf1bd811d78de2b4c973ece0f92af.0
Call-ID: fb224c2-071e4248-d1eb4f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:55:07.081: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKa5d2.b645c2b5f01c6bfccec94e83f04b65f6.0
Call-ID: fb224c2-171e4248-d1eb4f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:55:07.085: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK554c.c2e355826bac87122cdbe0ba2b6cf4dd.0
Call-ID: fb224c2-271e4248-d1eb4f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:55:07.093: //20449/9EA1F72EBA40/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK95a.79dcf1bd811d78de2b4c973ece0f92af.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADB5974-BD2
Date: Fri, 12 Sep 2014 14:55:07 GMT
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 8974 4855 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:55:07.093: //20450/9EA29355BA41/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKa5d2.b645c2b5f01c6bfccec94e83f04b65f6.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADB5978-1804
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 6149 9489 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:55:07.093: //20451/9EA32F7DBA42/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK554c.c2e355826bac87122cdbe0ba2b6cf4dd.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADB597C-18E4
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 2071 1878 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:55:11.877: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
From: "WIRELESS CALLER" <sip:+12145579949@fl.gg>;tag=gK027f79e5
Max-Forwards: 66
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKd862.52f425dc30e046be991c0267e0ee5471.0
Via: SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKd862.3aaee5365990f0219ef996c4d12d62fc.1
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKd862.c4e86d783c66cabf8d12c9be69fe00e4.0
Via: SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK02B57973763932aa8be
Call-ID: 738347232_25601132@4.55.17.35
CSeq: 15074 INVITE
Content-Length:  215
v=0
o=- 29297 21945 IN IP4 4.55.17.2
s=-
c=IN IP4 4.55.17.2
t=0 0
m=audio 7898 RTP/AVP 0 8 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=maxptime:20
Sep 12 14:55:11.885: //-1/A17F029BBA43/CCAPI/cc_api_display_ie_subfields:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=19729965165
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 12 14:55:11.889: //-1/A17F029BBA43/CCAPI/cc_api_call_setup_ind_common:
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=20452
Sep 12 14:55:11.889: //-1/A17F029BBA43/CCAPI/ccCheckClipClir:
Sep 12 14:55:11.889: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 12 14:55:11.889: :cc_get_feature_vsa malloc success
Sep 12 14:55:11.889:  cc_get_feature_vsa count is 1
Sep 12 14:55:11.889: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633792,feature_id:380
Sep 12 14:55:11.889: //20452/A17F029BBA43/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Sep 12 14:55:11.889: //20452/A17F029BBA43/CCAPI/cc_process_call_setup_ind:
   Event=0x4B198F30
Sep 12 14:55:11.889: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Sep 12 14:55:11.893: //20452/A17F029BBA43/CCAPI/ccCallSetContext:
   Context=0x4E130B70
Sep 12 14:55:11.893: //20452/A17F029BBA43/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 20452 with tag 4 to app "_ManagedAppProcess_Default"
Sep 12 14:55:11.897: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKd862.52f425dc30e046be991c0267e0ee5471.0,SIP/2.0/UDP 216.115.69.131;branch=z9hG4bKd862.3aaee5365990f0219ef996c4d12d62fc.1,SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKd862.c4e86d783c66cabf8d12c9be69fe00e4.0,SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK02B57973763932aa8be
Date: Fri, 12 Sep 2014 14:55:11 GMT
CSeq: 15074 INVITE
Content-Length: 0
Sep 12 14:55:11.897: //20452/A17F029BBA43/CCAPI/ccCallProceeding:
Sep 12 14:55:11.901: //20452/A17F029BBA43/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4E11D480, Progress Indication=NULL(0)
Sep 12 14:55:11.901: //20452/A17F029BBA43/CCAPI/ccCheckClipClir:
   Guid=A17F029B-39C3-11E4-BA43-A4D202FD5342, Outgoing Dial-peer=3
Sep 12 14:55:11.901: //20452/A17F029BBA43/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Sep 12 14:55:11.901: //20452/A17F029BBA43/CCAPI/ccIFCallSetupRequestPrivate:
Sep 12 14:55:11.901: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 12 14:55:11.901: :cc_get_feature_vsa malloc success
Sep 12 14:55:11.901:  cc_get_feature_vsa count is 2
Sep 12 14:55:11.901: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633568,feature_id:381
Sep 12 14:55:11.901: //20453/A17F029BBA43/CCAPI/ccIFCallSetupRequestPrivate:
Sep 12 14:55:11.901: //20453/A17F029BBA43/CCAPI/ccCallSetContext:
   Context=0x4E11D430
Sep 12 14:55:11.901: //20452/A17F029BBA43/CCAPI/ccSaveDialpeerTag:
Sep 12 14:55:11.905: //20453/A17F029BBA43/CCAPI/cc_api_call_proceeding:
   Interface=0x49FC41F0, Progress Indication=NULL(0)
Sep 12 14:55:11.913: //20453/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2001@10.1.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK2662178
From: "WIRELESS CALLER" <sip:1-972-996-5165@sip.flowroute.com>;tag=ADB6C54-1611
To: <sip:2001@10.1.1.2>
Call-ID: A182AB8B-39C311E4-BA49A4D2-2FD5342@10.1.1.1
Min-SE:  1800
Cisco-Guid: 2709455515-0969085412-3124995282-0050156354
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1410533711
Contact: <sip:1-972-996-5165@10.1.1.1:5060>
Call-Info: <sip:10.1.1.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 65
Content-Disposition: session;handling=required
Content-Length: 179
v=0
o=CiscoSystemsSIP-GW-UserAgent 6589 9590 IN IP4 10.1.1.1
s=SIP Call
c=IN IP4 10.1.1.1
t=0 0
m=audio 18774 RTP/AVP 0
c=IN IP4 10.1.1.1
a=rtpmap:0 PCMU/8000
a=ptime:20
Sep 12 14:55:11.921: //20453/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <sip:2001@10.1.1.2>;tag=cue7ed19ffa
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:2001@10.1.1.2:5060>
Sep 12 14:55:11.941: //20453/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Sep 12 14:55:11.941: //20453/A17F029BBA43/CCAPI/cc_api_call_alert:
   Interface=0x49FC41F0, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Sep 12 14:55:11.945: //20452/A17F029BBA43/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Sep 12 14:55:11.945: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+19729965165@fl.gg>;tag=ADB6C78-13DD
CSeq: 15074 INVITE
Contact: <sip:19729965165@71.170.37.123:5060>
Record-Route: <sip:216.115.69.144;lr>,<sip:216.115.69.132;lr>
Content-Length: 0
Sep 12 14:55:11.965: //20453/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 170
Call-Info: <sip:10.1.1.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 2583 2583 IN IP4 10.1.1.2
s=SIP Call
c=IN IP4 10.1.1.2
t=0 0
m=audio 16904 RTP/AVP 0
a=rtpmap:0 pcmu/8000
a=ptime:20
Sep 12 14:55:11.969: //20453/A17F029BBA43/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=20453,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
Sep 12 14:55:11.969: //20453/A17F029BBA43/CCInterface=0x0, Destination Call Id=20453, Source Call Id=20452,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
Sep 12 14:55:11.969: //20452/A17F029BBA43/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=20453, Source Call Id=20452,
Sep 12 14:55:11.969: //20453/A17F029BBA43/CCAPI/cc_api_event_indication:
   Event=171, Call Id=20453
   Caps(Playout Mode=1, Playout Initial=60=0x0
Sep 12 14:55:11.973: //20452/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:11.973: cc_api_get_xcode_stream : 4702
Sep 12 14:55:11.973: //20453/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:11.973: //20452/A17F029BBA43/CCAPI/ccConferenceCreate:
   (ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(
Sep 12 14:55:11.973: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=8,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
   delay media to slow start case, codec negotation is not done
   ms))
   Destination Event Is Sent To Conferenced SPI(s) Directly
Sep 12 14:55:11.969: //20453/A17F029BBA43/CCAPI/cc_api_call_connected:
   Interface=0x49FC41F0, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
   (confID=0x4AEB491C, callID1=0x4FE4, gcid=A17F9EC3-39C311E4-BA46A4D2-2FD5342, tag=0x0)
Sep 12 14:55:11.973: //20453/A17F029BBA43/CCAPI/ccConferenceCreate:
   (confID=0x4AEB491C, callID2=0x4FE5, gcid=A17F9EC3-39C311E4-BA46A4D2-2FD5342, tag=0x0)
   Conference Id=0x4AEB491C, Call Id1=20452, Call Id2=20453, Tag
Sep 12 14:55:11.977: //20452/A17F029BBA43/CCAPI/cc_api_bridge_done:
   Conference Id=0x18, Source Interface=0x49FC41F0, Source Call Id=20452,
   Destination Call Id=20453, Disposition=0x0, Tag=0x0
Sep 12 14:55:11.977: //20453/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:11.977: cc_api_get_xcode_stream : 4702
Sep 12 14:55:11.977: //20453/A17F029BBA43/CCAPI/cc_api_bridge_done:
   Conference Id=0x18, Source Interface=0x49FC41F0, Source Call Id=20453,
   Destination Call Id=20452, Disposition=0x0, Tag=0x0
Sep 12 14:55:11.977: //20452/A17F029BBA43/CCAPI/cc_generic_bridge_done:
Sep 12 14:55:11.977: //20452/A17F029BBA43/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x18, Destination Call Id=20453)
Sep 12 14:55:11.977: //20453/A17F029BBA43/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x18, Destination Call Id=20452)
Sep 12 14:55:11.977: //20452/A17F029BBA43/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x18, Call Id1=20452, Call Id2=20453
Sep 12 14:55:11.977: //20453/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2001@10.1.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK2679AE
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sep 12 14:55:11.981: //20452/A17F029BBA43/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Sep 12 14:55:11.985: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 15074 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 4128 9687 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=audio 18994 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
Sep 12 14:55:12.057: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:19729965165@71.170.37.123:5060 SIP/2.0
Max-Forwards: 67
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKd862.3fecfdb616e48aa913fc7b959d85b992.0
Via: SIP/2.0/UDP 216.115.69.132;branch=z9hG4bKd862.878a6ca20fb6dda0ca55367778cb0b98.0
Via: SIP/2.0/UDP 4.55.17.35:5060;branch=z9hG4bK02B57a36527eeda0e53
CSeq: 15074 ACK
Content-Length: 0
Sep 12 14:55:21.690: //20452/A17F029BBA43/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x4FE5
Sep 12 14:55:21.690: //20452/A17F029BBA43/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
Sep 12 14:55:21.690: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
 Sending: Binary Message Body
Sep 12 14:55:21.690: Content-Type: audio/telephone-event
01 00 07 D0
Sep 12 14:55:21.694: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:2001@10.1.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK268FF4
CSeq: 102 NOTIFY
Max-Forwards: 70
Date: Fri, 12 Sep 2014 14:55:21 GMT
Event: telephone-event
Subscription-State: active
Contact: <sip:10.1.1.1:5060>
Content-Length: 4
.P
Sep 12 14:55:21.702: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: message-summary
Sep 12 14:55:21.842: //20452/A17F029BBA43/CCAPI/cc_api_call_digit_end:
Sep 12 14:55:21.842: //20452/A17F029BBA43/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
Sep 12 14:55:21.842: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sep 12 14:55:21.842: Content-Type: audio/telephone-event
01 80 00 91
Sep 12 14:55:21.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK26910B2
CSeq: 103 NOTIFY
Max-Forwards: 70
Content-Length: 4
Sep 12 14:55:21.870: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 103 NOTIFY
Content-Length: 0
Allow-Events: refer
Sep 12 14:55:21.990: //20452/A17F029BBA43/CCAPI/cc_api_call_digit_begin:
Sep 12 14:55:21.990: //20452/A17F029BBA43/CCAPI/cc_relay_digit_begin_for_3way_conference:
Sep 12 14:55:21.990: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sep 12 14:55:21.990: Content-Type: audio/telephone-event
01 00 07 D0
Sep 12 14:55:21.994: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK26A22E0
CSeq: 104 NOTIFY
Max-Forwards: 70
Content-Length: 4
.P
Sep 12 14:55:21.998: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 104 NOTIFY
Content-Length: 0
Allow-Events: refer
Sep 12 14:55:22.142: //20452/A17F029BBA43/CCAPI/cc_api_call_digit_end:
Sep 12 14:55:22.142: //20452/A17F029BBA43/CCAPI/cc_relay_digit_end_for_3way_conference:
Sep 12 14:55:22.142: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sep 12 14:55:22.142: Content-Type: audio/telephone-event
01 80 00 96
Sep 12 14:55:22.142: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK26B25AA
CSeq: 105 NOTIFY
Max-Forwards: 70
Date: Fri, 12 Sep 2014 14:55:22 GMT
Content-Length: 4
Sep 12 14:55:22.158: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 105 NOTIFY
Content-Length: 0
Allow-Events: refer
Sep 12 14:55:22.290: //20452/A17F029BBA43/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0x4FE5
Sep 12 14:55:22.290: //20452/A17F029BBA43/CCAPI/cc_relay_digit_begin_for_3way_conference:
Sep 12 14:55:22.290: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sep 12 14:55:22.290: Content-Type: audio/telephone-event
00 00 07 D0
Sep 12 14:55:22.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK26CE7C
CSeq: 106 NOTIFY
Max-Forwards: 70
Content-Length: 4
..P
Sep 12 14:55:22.298: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 106 NOTIFY
Content-Length: 0
Allow-Events: refer
Sep 12 14:55:22.442: //20452/A17F029BBA43/CCAPI/cc_api_call_digit_end:
Sep 12 14:55:22.442: //20452/A17F029BBA43/CCAPI/cc_relay_digit_end_for_3way_conference:
Sep 12 14:55:22.442: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Sep 12 14:55:22.442: Content-Type: audio/telephone-event
00 80 00 96
Sep 12 14:55:22.442: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.1.1:5060;branch=z9hG4bK26D2136
CSeq: 107 NOTIFY
Max-Forwards: 70
Content-Length: 4
Sep 12 14:55:22.446: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 107 NOTIFY
Content-Length: 0
Allow-Events: refer
Sep 12 14:55:24.398: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKec1d.8eb53b0b8aa82890b4dbd1b3169e2010.0
Via: SIP/2.0/UDP 70.167.153.136:5060;branch=0
Call-ID: 0c26e475-cac1f078-616eb58@70.167.153.136
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:55:24.402: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKcf09.80371487deeb2499b173d1448e88733c.0
Call-ID: 0c26e475-eac1f078-616eb58@70.167.153.136
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:55:24.406: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK9d0b.b6b83c8e900863fcbafbf3a75df34327.0
Call-ID: 0c26e475-dac1f078-616eb58@70.167.153.136
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:55:24.414: //20454/A8F4DA02BA4A/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKec1d.8eb53b0b8aa82890b4dbd1b3169e2010.0,SIP/2.0/UDP 70.167.153.136:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADB9D1C-1E79
Date: Fri, 12 Sep 2014 14:55:24 GMT
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 9612 3862 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:55:24.414: //20455/A8F57629BA4B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bKcf09.80371487deeb2499b173d1448e88733c.0,SIP/2.0/UDP 70.167.153.136:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADB9D24-13D1
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 9238 6899 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:55:24.418: //20456/A8F61251BA4C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK9d0b.b6b83c8e900863fcbafbf3a75df34327.0,SIP/2.0/UDP 70.167.153.136:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADB9D28-54D
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 6623 7554 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:55:27.734: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:10.1.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.1.2:5060;branch=z9hG4bKvXn.hJCrhqQ8IuTEBcovRg~~23
Max-Forwards: 70
To: <sip:1-972-996-5165@sip.flowroute.com>;tag=ADB6C54-1611
CSeq: 1 BYE
Content-Length: 0
Also: <sip:110@10.1.1.1:5060;user=phone>
Sep 12 14:55:27.734: //20452/A17F029BBA43/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=20452
Sep 12 14:55:27.734: //20453/A17F029BBA43/CCAPI/cc_api_call_facility:
   Interface=0x49FC41F0, Call Id=20453
Sep 12 14:55:27.734: //20453/A17F029BBA43/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Sep 12 14:55:27.734: //20452/A17F029BBA43/CCAPI/ccConferenceDestroy:
   Conference Id=0x18, Tag=0x0
Sep 12 14:55:27.734: //20452/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:27.734: cc_api_get_xcode_stream : 4702
Sep 12 14:55:27.734: //20453/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:27.734: //20452/A17F029BBA43/CCAPI/cc_api_bridge_drop_done:
Sep 12 14:55:27.738: //20453/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:27.738: cc_api_get_xcode_stream : 4702
Sep 12 14:55:27.738: //20452/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Sep 12 14:55:27.738: //20453/A17F029BBA43/CCAPI/cc_api_bridge_drop_done:
Sep 12 14:55:27.738: //20452/A17F029BBA43/CCAPI/cc_generic_bridge_done:
Sep 12 14:55:27.738: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 12 14:55:27.738: :cc_get_feature_vsa malloc success
Sep 12 14:55:27.738:  cc_get_feature_vsa count is 3
Sep 12 14:55:27.738: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633344,feature_id:382
Sep 12 14:55:27.738: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Sep 12 14:55:27.738:  feature_vsa is 4C54EAD8,featname is 0
Sep 12 14:55:27.738:  cc_get_feature_vsa count is 4
Sep 12 14:55:27.738: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633120,feature_id:383
Sep 12 14:55:27.738: : Generating new featurevsa,inserting it
Sep 12 14:55:27.738:  feature call forward featname is 4
Sep 12 14:55:27.738:  feature_vsa is 4C54EBB8,featname is 0
Sep 12 14:55:27.738:  cc_get_feature_vsa count is 5
Sep 12 14:55:27.738: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280632224,feature_id:384
Sep 12 14:55:27.738: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 12 14:55:27.738: :cc_free_feature_vsa freeing 4C54E9F8
Sep 12 14:55:27.738:  vsacount in free is 4
Sep 12 14:55:27.738: //20453/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "WIRELESS CALLER" <sip:1-972-996-5165@sip.flowroute.com>;tag=ADB6C54-1611
Date: Fri, 12 Sep 2014 14:55:27 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=784,OS=125440,PR=657,OR=104325,PL=0,JI=0,LA=0,DU=15
Content-Length: 0
Sep 12 14:55:27.742: //20452/A17F029BBA43/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
Sep 12 14:55:27.742: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 12 14:55:27.742: :cc_get_feature_vsa malloc success
Sep 12 14:55:27.742:  cc_get_feature_vsa count is 5
Sep 12 14:55:27.742: :FEATURE_VSA attributes are: feature_name:0,feature_time:1280633344,feature_id:385
Sep 12 14:55:27.742: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Sep 12 14:55:27.742: : updating existing feature vsa
Sep 12 14:55:27.742:  feature call forward featname is 4
Sep 12 14:55:27.742: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 12 14:55:27.742: :cc_free_feature_vsa freeing 4C54E9F8
Sep 12 14:55:27.742:  vsacount in free is 4
Sep 12 14:55:27.742: //20452/A17F029BBA43/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Sep 12 14:55:27.742: //20452/A17F029BBA43/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=FALSE)
Sep 12 14:55:27.742: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 110
Sep 12 14:55:27.742: //20452/A17F029BBA43/CCAPI/ccCallTransferRequest:
   Transfer Info=0x4BEA2E20, Call Id=20452, Peer=20001
Sep 12 14:55:27.750: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Sent:
y/IOS-12.x
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1410533727
Expires: 180
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 4128 9688 IN IP4 71.170.37.123
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendonly
Sep 12 14:55:28.566: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 71.170.37.123:5060;branch=z9hG4bK26E8FA
To: "WIRELESS CALLER" <sip:+12145579949@fl.gg>;tag=gK027f79e5
CSeq: 101 INVITE
Content-Length: 0
Sep 12 14:55:28.574: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:+12145579949@4.55.17.35:5060 SIP/2.0
Via: SIP/2.0/UDP 71.170.37.123:5060;branch=z9hG4bK271598
CSeq: 102 REFER
Max-Forwards: 70
Route: <sip:216.115.69.132;lr>,<sip:216.115.69.144;lr>
Timestamp: 1410533728
Refer-To: sip:110@71.170.37.123
Referred-By: <sip:19729965165@sip.flowroute.com>
Content-Length: 0
Sep 12 14:55:29.030: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+12145579949@4.55.17.35:5060 SIP/2.0
Via: SIP/2.0/UDP 71.170.37.123:5060;branch=z9hG4bK2721B0C
Max-Forwards: 70
Timestamp: 1410533729
CSeq: 103 BYE
Also: <sip:110@71.170.37.123>
P-RTP-Stat: PS=657,OS=104325,PR=839,OR=125816,PL=0,JI=0,LA=0,DU=17
Content-Length: 0
Sep 12 14:55:29.898: //20452/A17F029BBA43/SIP/Msg/ccsipDisplayMsg:
Received:
Sep 12 14:56:02.411: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK18e.26c242e1f5366b4396594eb0180c6987.0
Call-ID: fb224c2-aaff4248-45eb4f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:56:02.415: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK3813.062a78194e88241b77a0ee2cff453bbc.0
Call-ID: fb224c2-baff4248-45eb4f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:56:02.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 10
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK5845.6ed45358d01328cc3ca61683f929f532.0
Call-ID: fb224c2-caff4248-45eb4f6@216.115.69.131
CSeq: 1 OPTIONS
Content-Length: 0
Sep 12 14:56:02.427: //20458/BF9DC5FDBA4D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK18e.26c242e1f5366b4396594eb0180c6987.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADC319C-25CB
Date: Fri, 12 Sep 2014 14:56:02 GMT
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 3363 8098 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:56:02.431: //20459/BF9E6225BA4E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK3813.062a78194e88241b77a0ee2cff453bbc.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADC31A0-12FF
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 2968 5381 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Sep 12 14:56:02.431: //20460/BF9EFEE5BA4F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 216.115.69.144;branch=z9hG4bK5845.6ed45358d01328cc3ca61683f929f532.0,SIP/2.0/UDP 216.115.69.131:5060;branch=0
To: sip:71.170.37.123:49832;tag=ADC31A4-C80
CSeq: 1 OPTIONS
Content-Length: 456
v=0
o=CiscoSystemsSIP-GW-UserAgent 3155 5454 IN IP4 71.170.37.123
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
router1#no debug all
All possible debugging has been turned off
router1#
Please try this
Shuresh beated me on time :)
+5 S
Disabling refer supplementary service should work
Carlo
That fixed it! Thanks
That fixed it! Thanks everyone!!!
I dont have any ACLs between
I dont have any ACLs between the router and the service engine.
My routers ACL is listed above, are there any changes you suggest?
The router has 512mb of ram
353
