Inbound Dial-Peer Matching Question
I have created separate dial-peers for inbound and outbound calls on th same voice-port (FXS) and I am not sure why a particular dial-peer is being match on the inbound call. If you look at my configuration below, a call is coming in from port 0/2/0 and it is matching the 301 pots dial-peer instead of 401 pots dial-peer. I thought that if I configured one dial-peer with "incoming called number ." and one with "destination-pattern", the dial-peer with "incoming called-number ." would be matched first. Now if dial-peer 301 is entered into the configuration below dial-peer 401, dial-peer 401 is selected first but I am not sure why.
dial-peer voice 101 pots
description Incoming Calls Dial Peer
direct-inward-dial
port 0/1/0:23
dial-peer voice 201 pots
description Outgoing Calls Dial Peer
destination-pattern 9T
port 0/1/0:23
dial-peer voice 301 pots
description Outgoing Calls to FXS-01
destination-pattern 7607102824
port 0/2/0
dial-peer voice 401 pots
description Incoming Calls from FXS-01
translation-profile incoming INBOUND_FROM_FXS_TO_CUBE
port 0/2/0
dial-peer voice 402 pots
description Incoming Calls from FXS-02
port 0/2/1
dial-peer voice 501 voip
description Outgoing Analog Dial-Peer to CUBE01
translation-profile outgoing OUTBOUND_TO_VZBSBC01
preference 1
destination-pattern 0001T
session protocol sipv2
session target ipv4:XXX.XXX.XXX.XXX
voice-class codec 2
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax-relay sg3-to-g3
fax rate 14400
fax nsf 000000
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
ip qos dscp cs5 media
no vad
dial-peer voice 502 voip
description Outgoing Analog Dial-Peer to CUBE02
preference 2
voice-class codec 2
fax-relay sg3-to-g3
fax rate 14400
fax nsf 000000
no vad
Any advice is greatly appreciated!
Tom
Everyone's tags (2)
1 REPLY
Below link with details the rules and priorities for dial-peer (inbound and outbound).
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html
Regards.
J Rosa.
3311
