inbound dial-peer not matched correctly
we have a gateway with the following configuration:
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
dial-peer voice 88 pots
trunkgroup ATT
description outbound Dialpeer for Tapestry
destination-pattern 889T
forward-digits 10
So, in theory if a call with DNIS 8890  hits the gateway, dial-peer 100 will be matched as "incoming called-number" has priority over
over the  answer-address  and  destination-pattern.
However, we made a test call  (with DNIS 8894), we saw the inbound dial-peer 88 is used:
xxxxxx#sh voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0xB2BD     247E 0x219E6FEC 0/0/0:23.9       0/1:1   8894       g711ulaw 100/88
0xB2BE     247E 0x22051AB0 0/1/0:23.1       0/1:2  *8894       g711ulaw  88/100
1 active call found
So is this a bug?
Re: inbound dial-peer not matched correctly
To me it looks like your hair-pinning the call.
First call leg
This is the incoming call, that hits incoming DP 100 and uses DP 88 in the outbound direction.
Second call leg
Outbound on another B channel, inbound DP is 88 and outbound is DP 100.
If you do a debug voip ccapi inout you would probably see that pretty clearly.
Please remember to rate helpful responses and identify helpful or correct answers.
Like Roger says, looks like hairpinning, in fact that single call is using 2 B-channels on your BRI.
what have you got configured under dial-peer 88's
trunkgroup ATT    ?????
are you pointing it back out to your BRI?
full config please
Please remember to rate useful posts, by clicking on the stars below.
Hall of Fame Super Silver
Please post "debug voice dialpeer".
Chris
183
