inbound external calls not working on 7961 Phones
Problem Description :
We have got a cisco ip phone user whose DID was previously being used on a Turret phone , we configured the same extension on the Cisco phone ( and removed it from the turret phone ) , but the issue is that when an inbound external calls comes on the DID , that Turret phone rings while the Cisco phone does not rings , while internally , it works perfectly fine.
Alll the calling search spaces and partition are correct.
CCM VERSION : 6.1.3
CISCO IP PHONE MODEL : 7961G
Whatever level you reach getting better never stops -- Sachin Tendulkar
1 REPLY
Hall of Fame Super Silver
What is the turret device, is it a SIP phone registered with CUCM?
Do you have shared line setup betwen the SIP phone and Cisco phone (same partition)? What is your eaxt setup?
Chris
403
