Inbound fax calls are failing but outgoing fax calls are working fine.
Hello Community,
I am having problems  with fax calls coming into my Call manager express router from an E1 port to a directly connected fxs port where my fax machine is connected.  has anyone ever encoutered this problem before? please see my logs and configs bellow.
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
___________________________________________
voice service pots
fax rate disable
_________________________________--
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol none
h323
modem passthrough nse codec g711ulaw
_________________________________________________
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 1 pots
destination-pattern 8907
port 0/1/2
_____________________________________________________
Nov 14 18:38:44.298: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '2035978001'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '118907'
Plan:ISDN, Type:Unknown
Nov 14 18:38:44.298: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8001 callID = 0x13E6 switch = primary-net5 interface = User
Nov 14 18:38:44.302: //-1/D32ADF0B93E7/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=90200008001
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=8907
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 14 18:38:44.302: //-1/D32ADF0B93E7/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x23323FA0, Call Info(
   Calling Number=90200008001,(Calling Name=)(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=8907(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Nov 14 18:38:44.302: //-1/D32ADF0B93E7/CCAPI/ccCheckClipClir:
   In: Calling Number=90200008001(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=90200008001(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
Nov 14 18:38:44.302: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 14 18:38:44.302: :cc_get_feature_vsa malloc success
Nov 14 18:38:44.302:  cc_get_feature_vsa count is 1
Nov 14 18:38:44.302: :FEATURE_VSA attributes are: feature_name:0,feature_time:1053315448,feature_id:68546
Nov 14 18:38:44.302: //38099/D32ADF0B93E7/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=90200008001(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=8907(TON=Unknown, NPI=ISDN))
Nov 14 18:38:44.302: //38099/D32ADF0B93E7/CCAPI/cc_process_call_setup_ind:
   Event=0x3CE6E9A0
Nov 14 18:38:44.302: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 8907
Nov 14 18:38:44.302: //38099/D32ADF0B93E7/CCAPI/ccCallSetContext:
   Context=0x21049084
   >>>>CCAPI handed cid 38099 with tag 100 to app "_ManagedAppProcess_Default"
Nov 14 18:38:44.302: //38099/D32ADF0B93E7/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Nov 14 18:38:44.306: //38099/D32ADF0B93E7/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x21E26154, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Nov 14 18:38:44.306: //38099/D32ADF0B93E7/CCAPI/ccCheckClipClir:
   Destination Pattern=8907, Called Number=8907, Digit Strip=TRUE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=D32ADF0B-4C92-11E3-93E7-F872EAC341D0, Outgoing Dial-peer=1
Nov 14 18:38:44.306: //38099/D32ADF0B93E7/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=8907
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov 14 18:38:44.306: //38099/D32ADF0B93E7/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3CED19B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=90200008001,(Calling Name=)(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=8907(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov 14 18:38:44.306: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 14 18:38:44.306: :cc_get_feature_vsa malloc success
Nov 14 18:38:44.306:  cc_get_feature_vsa count is 2
Nov 14 18:38:44.306: :FEATURE_VSA attributes are: feature_name:0,feature_time:1053320152,feature_id:68547
Nov 14 18:38:44.306: //38100/D32ADF0B93E7/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Nov 14 18:38:44.306: //38100/D32ADF0B93E7/CCAPI/ccCallSetContext:
   Context=0x21E26104
Nov 14 18:38:44.306: //38099/D32ADF0B93E7/CCAPI/ccSaveDialpeerTag:
Nov 14 18:38:44.306: htsp_timer_stop3 htsp_setup_req
Nov 14 18:38:44.310:  Orig called num:8907
Nov 14 18:38:44.310: htsp_process_event: [0/1/2, FXSLS_ONHOOK, E_HTSP_SETUP_REQ]fxsls_onhook_setuphtsp_alert
Nov 14 18:38:44.310: [0/1/2] set signal state = 0x0 timestamp = 0
Nov 14 18:38:44.310: [0/1/2] htsp_set_caller_id_tx calling num=90200008001 display_info= called num=8907
Nov 14 18:38:44.310: [0/1/2] Caller ID String 80 19 01 08 31 31 31 34 31 38 33 38 02 0A 32 30 30 30 30 30 38 30 30 31 08 01 4F 5C
Nov 14 18:38:44.310: [0/1/2] htsp_set_caller_id_tx_time Caller ID:BELLCORE alerting DURING_RING
Nov 14 18:38:44.310: [0/1/2] htsp_start_caller_id_tx string length=28
Nov 14 18:38:44.310: //38100/D32ADF0B93E7/CCAPI/cc_api_call_proceeding:
   Interface=0x3CED19B8, Progress Indication=NULL(0)
Nov 14 18:38:44.310: //38100/D32ADF0B93E7/CCAPI/cc_api_call_alert:
   Interface=0x3CED19B8, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Nov 14 18:38:44.310: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
Nov 14 18:38:44.310: //38099/D32ADF0B93E7/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x94D3, gcid=D32ADF0B-4C9211E3-93E7F872-EAC341D0, tag=0x0)
Nov 14 18:38:44.314: //38100/D32ADF0B93E7/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x94D4, gcid=D32ADF0B-4C9211E3-93E7F872-EAC341D0, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=38099, Call Id2=38100, Tag=0x0
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/cc_api_bridge_done:
   Conference Id=0x2C7B, Source Interface=0x23323FA0, Source Call Id=38099,
   Destination Call Id=38100, Disposition=0x0, Tag=0xFFFFFFFF
Nov 14 18:38:44.314: htsp_call_bridged invoked
Nov 14 18:38:44.314: //38100/D32ADF0B93E7/CCAPI/cc_api_bridge_done:
   Conference Id=0x2C7B, Source Interface=0x3CED19B8, Source Call Id=38100,
   Destination Call Id=38099, Disposition=0x0, Tag=0xFFFFFFFF
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x2C7B, Destination Call Id=38100)
   Call Entry(Conference Id=0x2C7B, Destination Call Id=38099)
Nov 14 18:38:44.314: confID:0x2C7B; callEntry1 callID1:0x94D3, type:6; callEntry2 callID2:0x94D4, type:6
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3CED19B8, Destination Call Id=38100, Source Call Id=38099,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Nov 14 18:38:44.314: //38100/D32ADF0B93E7/CCAPI/cc_api_caps_ind:
   Destination Interface=0x23323FA0, Destination Call Id=38099, Source Call Id=38100,
Nov 14 18:38:44.314: //38100/D32ADF0B93E7/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4311)
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1506)
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2C7B, Call Id1=38099, Call Id2=38100
Nov 14 18:38:44.314: //38100/D32ADF0B93E7/CCAPI/cc_api_voice_mode_event:
   Call Id=38100
   Call Entry(Context=0x21E26104)
Nov 14 18:38:44.314: htsp_process_event: [0/1/2, FXSLS_WAIT_OFFHOOK, E_HTSP_VOICE_CUT_THROUGH]fxsls_waitoff_voice
Nov 14 18:38:44.314: //38099/D32ADF0B93E7/CCAPI/cc_api_voice_mode_event:
   Call Id=38099
   Call Entry(Context=0x21049084)
Nov 14 18:38:44.318: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8001
Progress Ind i = 0x8188 - In-band info or appropriate now available
Nov 14 18:38:46.806: htsp_process_event: [0/1/2, FXSLS_WAIT_OFFHOOK, E_DSP_SIG_1100]fxsls_waitoff_offhook
Nov 14 18:38:46.806: [0/1/2] set signal state = 0x4 timestamp = 0
Nov 14 18:38:46.806: [0/1/2] set signal state = 0x6 timestamp = 200
Nov 14 18:38:46.806: [0/1/2] htsp_stop_caller_id_tx
Nov 14 18:38:46.806: htsp_timer2 - 200 msec
Nov 14 18:38:46.806: htsp_timer_stop3
Nov 14 18:38:47.006: htsp_process_event: [0/1/2, FXSLS_WAIT_OFFHOOK, E_HTSP_EVENT_TIMER2]fxsls_offhook_dial htsp_dial
Nov 14 18:38:47.006: //38100/D32ADF0B93E7/CCAPI/cc_api_call_connected:
   Interface=0x3CED19B8, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Nov 14 18:38:47.006: htsp_process_event: [0/1/2, FXSLS_CONNECT, E_DSP_DIALING_DONE]fxsls_conn_dial_done
Nov 14 18:38:47.006: //38099/D32ADF0B93E7/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Nov 14 18:38:47.006: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x8001
Progress Ind i = 0x8182 - Destination address is non-ISDN
Nov 14 18:38:47.078: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0001
Nov 14 18:38:49.346: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
   Feature Type=2, Interface=0x3CED19B8, Call Id=38100
Nov 14 18:38:49.346: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
   Feature Type=2, Call Id=38099
Nov 14 18:38:49.362: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
   Feature Type=13, Interface=0x23323FA0, Call Id=38099
Nov 14 18:38:49.362: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
   Feature Type=13, Call Id=38100htsp_call_feature:feature 13
Nov 14 18:38:49.386: //38100/D32ADF0B93E7/CCAPI/cc_api_modify_media_ind:
   IFType=0x6, Source Call Id=0x94D4, Destination Call Id=0x94D3,
   Codec=1, Codec Bytes=160
Nov 14 18:38:49.406: //38099/D32ADF0B93E7/CCAPI/cc_api_modify_media_ind:
   IFType=0x6, Source Call Id=0x94D3, Destination Call Id=0x94D4,
Nov 14 18:38:51.262: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
   Feature Type=1, Interface=0x23323FA0, Call Id=38099
Nov 14 18:38:51.262: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
   Feature Type=1, Call Id=38100htsp_call_feature:feature 1
Nov 14 18:38:51.462: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:51.462: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:51.662: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:51.662: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:51.874: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:51.874: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:52.074: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:52.074: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:52.274: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:52.274: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:52.462: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
   Feature Type=1, Interface=0x3CED19B8, Call Id=38100
Nov 14 18:38:52.462: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
   Feature Type=1, Call Id=38099
Nov 14 18:38:52.486: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:52.486: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:52.686: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:52.686: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:52.890: //38099/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:52.890: //38100/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:38:57.626: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:38:57.626: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:39:02.786: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:39:02.786: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:39:07.934: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:39:07.934: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:39:13.106: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:39:13.106: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:39:18.254: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:39:18.254: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:39:23.426: //38100/D32ADF0B93E7/CCAPI/cc_api_call_feature:
Nov 14 18:39:23.426: //38099/D32ADF0B93E7/CCAPI/ccCallFeature:
Nov 14 18:39:25.078: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0001
Cause i = 0x8AA9 - Temporary failure
Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov 14 18:39:25.078: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x13E6
Nov 14 18:39:25.078: //38099/D32ADF0B93E7/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=41, Progress Indication=INBAND(8), Interface=0x23323FA0
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
Nov 14 18:39:25.078: //38099/D32ADF0B93E7/CCAPI/ccConferenceDestroy:
   Conference Id=0x2C7B, Tag=0x0
Nov 14 18:39:25.078: confID:0x2C7B; callEntry1 callID1:0x94D3, type:6; callEntry2 callID2:0x94D4, type:6
Nov 14 18:39:25.078: //38099/D32ADF0B93E7/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=38100, Disposition=0x0, Tag=0x0
Nov 14 18:39:25.078: //38100/D32ADF0B93E7/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=38099, Disposition=0x0, Tag=0x0
Nov 14 18:39:25.078: //38099/D32ADF0B93E7/CCAPI/cc_generic_bridge_done:
Nov 14 18:39:25.082: //38099/D32ADF0B93E7/CCAPI/ccCallDisconnect:
   Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
   Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
Nov 14 18:39:25.082: //38099/D32ADF0B93E7/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Nov 14 18:39:25.082: //38100/D32ADF0B93E7/CCAPI/ccCallDiscon
Can you please add:
forward digits 0 <-- Maybe the Fax doesn't like to receive digits
port 0/1/2
Debugs:
1100 = FXO port went off-hook
So far it looks fine, the call connects, but after a minute or so: 18:38:46.806 - 18:39:25.078, TELCO sends a Temp Failure:
ISDN Cause Codes:
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
Cause Code Origination Point
8A - a network beyond the internetworking           point
A9 - Temporary failure - "An error occurs because of a network malfunction. Contact the                 telco if the problem persists."
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
The funny thing is that  that outbound fax works fine. really strange.
Did you notice that VAD was enabled during the capability negociation. I alwasy thought Fax communication hated VAD?  Are you able to shed some light on why we are seing VAD even though it is not configured on the POTs dial-peer? I did not even find an option of disabeling it on POTs dial-peer?
any thoughts on this?
321
