Inbound FXO calls on a remote router
Have a remote router in a small branch office that has 2 fxo cards set up. Have a tunnel on the T1 set back to Call manager 4.1(3) as an mgcp gateway. Have outbound calls set up and working. Not sure how to set up inbound calls. Can any one point me in the right direction. Want to find a way to have them show up as an extension or point them to an extension.
Keith
1 REPLY
Silver
Re: Inbound FXO calls on a remote router
Two important things to remember:
1) You have to have make sure the MGCP enabled dial-peers appear before any H323 dial-peers. These are usually the dial-peers that start with 999 or something similar.
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
2) Then you have to add the following voiceport configuration for PLAR
voice-port 0/2/0
connection plar
Please rate posts if you find them useful
89
