Inbound FXO Port Ring Issue CCME
Hello
I have an issue where one of my agents is having issues with inbound calls from the Telco. The call rings 3 times on the Telco side before ringing the FXO port on my router.
1861 Router with CCME Configuration is as follows:
voice-port 0/1/0
trunk-group FXO
connection plar opx 75303
caller-id enable
voice-port 0/1/1
trunk-group FXO
caller-id enable
dial-peer voice 1 pots
trunkgroup FXO
incoming called-number .
direct-inward-dial
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 8
sdspfarm tag 1 xCoder
em logout 0:0 0:0 0:0
max-ephones 8
max-dn 48
ip source-address 172.28.XXX.XXX port 2000
auto assign 1 to 8
timeouts ringing 6
cnf-file location flash:
cnf-file perphone
load 7941 term41.default
load 7961 term61.default
time-zone 5
voicemail 55
max-conferences 4 gain -6
call-forward pattern .T
moh flash:MOHCCME.au
web admin system name admin password XXXXXXXX
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Oct 03 2008 10:44:14
ephone-dn  1  dual-line
number 75303
ephone  1
no multicast-moh
device-security-mode none
mac-address XXXX.XXXX.XXXX
type 7941
button  1:1
Dennis M. Ferree
Hall of Fame Super Gold
Re: Inbound FXO Port Ring Issue CCME
Do you have caller-id working ?
Yes Caller ID works when it rings the phone on the fourth ring.  The FXO port rings 3 times then on the 4 ring it rings the 7941 phone with caller ID, then it rings 3 more times on the FXO and 4th ring on 7941 no caller ID.
Seems like router is waiting for caller-id to be delivered then.
You can verify that with "debug vpm signal", make sure you have service timestapm debug msec enabled.
There is also an option in "caller-id" to make it faster, can't remember the keyword now.
560
