Inbound International Call Question
Hello, I am receiving complaints that people outside the U.S. are dialing our number and are then prompted with a second dial tone.  They then re-dial the number and it will ring through to our phones.  My question is where is this secondary dial tone coming from?  Thanks for your help!
1 ACCEPTED SOLUTION
Add "direct-inward-dial" on
Add "direct-inward-dial" on your inbound POTS dialpeer.
Example:
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
Look at your call flow to
Look at your call flow to determine where it might be coming from.
No way to tell without more info, that's why you need to look at how the call flow is handled in your environment.
java
if this helps, please rate
www.cisco.com/go/pdi
Example:
direct-inward-dial
Hi, this come from the
Hi, this come from the gateway which is set to run a two stage call, if you want to be in one stage with on dial tone configure DID.
42
