Inbound PSTN - Forward PSTN - No Way Audio
jdcutcher
Here's a description, and I'll try to be brief.
Call Manager 4.1
2821 router
T1 (2 port) Multi-Flex Trunk WAN daughter card
We're finding that inbound calls from the PSTN that are forwarded back out to the PSTN will generate a ring for the called number, they answer, no audio. On the calling end, they hear ring no answer.
So, I believe this will be a problem with the T1 in question, but I don't know what the problem is.
Also of note... forwarding internally and externally from inside works. So it's only a hairpin call that triggers condition.
The following is some of the configuration involved for this card.
no network-clock-participate wic 3
controller T1 0/3/0
framing esf
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/3/1
framing esf
linecode b8zs
interface Serial0/3/0:0
no ip address
encapsulation ppp
ppp multilink
ppp multilink group 1
interface Serial0/3/1:0
no ip address
encapsulation ppp
ppp multilink
The interface is reporting errors.
Thanks for any feedback!
You can try this command:
voice-card 0
no local-bypass
I don't suspect that it will fix the problem, but it is worth a try. What type of errors are you getting?
The PPP link is not a voice circuit, so if calls are going out of that link they aren't really 'hairpinned', and it's most likely a routing/firewall issue.
Clarification would help.
-nick
