Community Member
inbound SIP call and Greetings
Hi all
I have the following setup :
PSTN--------SIPTRUNK -------2901----H323-------CUCM8.6-------Internal
The outbound calls not active in this session as per my managment requests
The direct call for each extension is fine 22846XX
if somebody from out side call any extension with voice mail / or calling to operator 2284600 with greeting message , he cannot insert any digit, I have tested the unity connection from inside it works fine,
"Welcome to ABC company if you know the extension dial it now , or press 0 for assestent"  when I press 0 or any extension I cant see any redierction or call transfere to the enrered ext.
all expected debugs in the attached file and here is the running
any idea is appreciated
Current configuration : 4892 bytes
! Last configuration change at 22:53:53 UTC Wed Oct 2 2013
! NVRAM config last updated at 22:53:55 UTC Wed Oct 2 2013
version 15.1
hostname VG
boot-start-marker
boot-end-marker
enable password admin
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 172.16.24.1 172.16.24.10
ip dhcp excluded-address 172.16.24.40 172.16.24.50
ip dhcp pool IPT
network 172.16.24.0 255.255.255.0
default-router 172.16.24.1
option 150 ip 172.16.24.42
trunk group XXX
hunt-scheme random
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 10.208.9.69
  ipv4 172.29.30.130
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol none
h323
sip
bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  header-passing
  error-passthru
  early-offer forced
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice class sip-profiles 1
request INVITE sip-header P-Asserted-Identity remove
request INVITE sip-header Allow-Header modify ", UPDATE" ""
request REINVITE sip-header Allow-Header modify ", UPDATE" ""
response 180 sip-header Allow-Header modify ", UPDATE" ""
response 200 sip-header Allow-Header modify ", UPDATE" ""
voice class custom-cptone fxo_call_disconnect
dualtone disconnect
  frequency 425
  cadence 250 250
voice translation-rule 1
rule 1 /22846../ /666/
voice translation-profile 1
translate calling 1
translate called 1
license udi pid CISCO2901/K9 sn FCZ164790AB
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
redundancy
translation-rule 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 172.16.24.3 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip h323-id VG
h323-gateway voip bind srcaddr 172.16.24.3
ip address 172.29.30.130 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.208.9.69 255.255.255.255 172.29.30.129
ip route 10.209.4.56 255.255.255.252 172.29.30.129
ip route 172.16.26.0 255.255.255.0 172.16.24.1
control-plane
voice-port 0/0/0
trunk-group XXX
cptone SA
caller-id enable
voice-port 0/0/1
trunk-group XXX
cptone SA
caller-id enable
voice-port 0/0/2
trunk-group XXX
cptone SA
caller-id enable
voice-port 0/0/3
trunk-group XXX
cptone SA
caller-id enable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.16.24.42 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 3 register hw_txd1
associate profile 1 register hw_mtp1
associate profile 2 register hw_cnf1
dspfarm profile 3 transcode universal
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
rsvp
maximum sessions 4
associate application SCCP
dspfarm profile 2 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 2
dspfarm profile 1 mtp
codec g711ulaw
rsvp
maximum sessions software 8
dial-peer voice 3400 voip
translation-profile incoming 1
destination-pattern [1-6]..
session target ipv4:172.16.24.42
incoming called-number 22846..
voice-class h323 1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 5001 pots
trunkgroup EMPOWER
destination-pattern 05........
no digit-strip
dial-peer voice 5002 pots
trunkgroup XXX
destination-pattern [1-9]......
no digit-strip
dial-peer voice 5004 pots
trunkgroup XXX
destination-pattern 00T
no digit-strip
dial-peer voice 5410 voip
session protocol sipv2
session target ipv4:10.208.9.69
session transport udp
dtmf-relay sip-notify
codec g711ulaw
sip-ua
registrar ipv4:172.29.30.130 expires 3600
sip-server ipv4:10.208.9.69:5060
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
1 REPLY
I had a quick look at the debugs and could see multiple calls.
As per the following call flow and the running config, dial peer 5410 (with SIPv2) should be selected for the incoming leg and dial peer 3400 should be selected for the outgoing leg.
ITSP -> SIP -> GW -> H323 -> CUCM
However, the dial peer 3400 is getting selected for the incoming leg (because of the command: incoming called-number 22846..)
Incoming dial peer=3400
Oct  2 22:35:25.874: //-1/xxxxxxxxxxxx/CCAPI/ccGetUriDataFromTDContainer:
   urlp=3139FDC4, urlp->original_url=sip:2284600@172.29.30.130;user=phoneInterface=0x2B2803A0, Call Info(
   Calling Number=sip:559669904@172.29.30.130;user=phone,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=sip:2284600@172.29.30.130;user=phone(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3400, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=26206
Outgoing dial peer selected is also 3400
Oct  2 22:35:25.878: //-1/xxxxxxxxxxxx/CCAPI/ccGetUriDataFromTDContainer:
   urlp=31A83A70, urlp->original_url=sip:559669904@172.29.30.130;user=phoneInterface=0x2B55F444, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=sip:559669904@172.29.30.130;user=phone,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=666(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3400, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct  2 22:35:25.878: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Is there any specific reason that you have added the "incoming called-number 22846.." to the h323 Voip Dial peer (3400) and no pattern configured to the SIP dial peer 5410?
If no, can you try to remove the command "incoming called-number 22846.." from dial peer 3400 and add it to dial peer 5410.
Also, please collect detailed call manager traces and the following debugs for one single test call initiated from a PSTN phone.
deb ccsip messages
deb voice ccapi inout
deb h225 asn1
deb h245 asn1
HTH,
Jagpreet Singh Barmi
192
