Inbound SIP calls issues
I been experiencing some weird behavior from inbound SIP calls. Outbound works great..
Ok this the dilemma. The calling party don't get a ring back while the called party rings. Called party picks up and the call drops after 10 seconds, in the mean time if the calling party don;t hang up the phone the called phone start ringing again as a new call where in fact the calling party never disconcerted the call.. This can continue all day in a loop if the calling party don;t hang up..
I hope i did explain it correcly.. This is some of the logs: If someone can give me any hints of what could be wrong greatly appreciated..
.Mar 28 01:42:37.829: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475780000@x.x.x.x:5060 SIP/2.0
Reason: Q.850;cause=86
Date: Wed, 28 Mar 2012 01:41:59 GMT
Timestamp: 1332898957
Content-Length: 0
User-Agent: Cisco-SIPGateway/IOS-12.x
To: "347570000" <sip:3475700000@x.x.x.x>;tag=as525083e9
Call-ID: 02d32716428add3450773fe80e6fdb70@x.x.x.x
Via: SIP/2.0/UDP 192.168.1.26:5060;branch=z9hG4bK1343D256D
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:41.828: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:347500000@64.154.x.x:5060 SIP/2.0
Timestamp: 1332898961
Content-Length: 0
To: "34757800000" <sip:3475780000@64.154.x.x>;tag=as525083e9
Call-ID: 02d32716428add3450773fe80e6fdb70@64.154.X.X
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:45.828: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475700000@64.154.X.X:5060 SIP/2.0
Timestamp: 1332898965
Content-Length: 0
To: "347570000" <sip:347570000@64.154.X.X>;tag=as525083e9
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:49.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475780000@64.154.X.X:5060 SIP/2.0
Timestamp: 1332898969
Content-Length: 0
To: "3475700000" <sip:3475780000@x.x.x.x>;tag=as525083e9
CSeq: 101 BYE
Max-Forwards: 70
.Mar 28 01:42:53.827: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3475784000@x.x.x.x:5060 SIP/2.0
Timestamp: 1332898973
Content-Length: 0
To: "3475780000" <sip:3475780000@64.154.X.X>;tag=as525083e9
CSeq: 101 BYE
Max-Forwards: 70
Could you please post complete debug for the call (starting with INVITE )
Thank you.
Re: Inbound SIP calls issues
Hello- Thanks for the reply, please see attached file..
The logs are incomplete. Also brief the call flow like what are components involved in the call flow
Senthil
Hall of Fame Super Gold
Maybe mention system type and version you have, and the exact complete call flow on all devices traversed.
Paolo,
My mistake, CME 7.1 on 2801 router 12.4(22)YB8..
Call flow PSTN-SIP Provider-CME 7.1- Cisco Phone7970..
Never mind- Got it.. It was a nat-ing issue.. got it to work.. Thank you guys!!
Can you let us know the solution.
Thanks a bunch
HI.
try add this commnand under service voip .
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
Best Regards
Marwan Urabi
Marwan I dont have that option ip address trusted list.. I'm running CUE 7.1 btw..
HI,
before 2 month i use CME 4.1 on Router 1760 and this conifg is work for me .
voice rtp send-recv
voice service pots
supplementary-service qsig call-forward
voice service voip
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.7
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
  registrar server expires max 3600 min 3600
after i upgrade to 8.5 on router 2811 , i have this problem and i solve it like this :
voice rtp send-recv
voice service pots
voice service voip
qsig decode
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 1200 min 660
i dont know if the ip address trusted list command avilable on CME 7.1,
Please check also 2 command under SIP
if is not work ,  please post your sample config and i will compare it with CME 4.1 i have it to .
Best Regards
Good Luck
Marwan
2801CME(conf-voi-serv)#ip address ?
% Unrecognized command
Looks like its not..:)
Actually I just found out that this is part of cisco's toll-fraud-prevention available on v 15.1(2)T and later.. I'm running v
12.4(13r)T..
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
1456
